Air pump function?
Old Feb 2, 2008 | 09:08 PM
iaus10's Avatar
Air pump function?
Hi. Recently bought a 55k mile rx8. Shortly after purchase, had squealing from under the hood, until car warmed up. Squealing eventually stopped during subsequent startups, but CEL for secondary air injection appeared.
Thought possibly air pump , so disconnected the air pump hose and found no air flow while car was running. Pump's air outlet smells kinda burnt. Thinking it may be bad, but a couple questions before buying a new one:
Is the air pump "always on", and the solenoid controls the flow to the exhaust? Or is there a relay that will periodically turn on the pump? Can't really tell from the service docs.
Thanks.
Old Feb 2, 2008 | 09:11 PM
mysql101's Avatar
airpump only runs for a short time when starting up cold. It's to push extra air into the cat. useful only for emissions.
many people remove it completely.
Old Feb 2, 2008 | 09:13 PM
iaus10's Avatar
Thanks, that makes sense. I had a friend start the car while I monitored the pump outlet. Didn't detect any airflow. Car wasn't super cold... but had cooled for about an hour since driving (if that matters).
Old Feb 2, 2008 | 09:14 PM
mysql101's Avatar
test it after the car has sat overnight.
Old Feb 2, 2008 | 09:17 PM
mysql101's Avatar
if you find out that yours is broken and you need to replace it, PM me. I recently removed mine.
Old Feb 2, 2008 | 09:23 PM
iaus10's Avatar
Cool... if it is the problem, that'll work out swell. I need to have no CEL and all OE parts for the stock class Autocrossing.
Old Feb 3, 2008 | 02:19 PM
iaus10's Avatar
Well, no air flow from from pump at startup (30 deg outside temp). There was an audible exhaust note from the air control valve for a few seconds, with the rubber air hose disconnected. So seems like the control valve was open and "expecting" some air from the pump at that point.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
05rx8mazda
Nov 28, 2015 09:42 AM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
