Me and the Exedy Hyper Stage 2 Clutch/Flywheel
Old Jan 20, 2008 | 11:54 PM
slavearm's Avatar
Boost Junkie
I have driven sticks for over 10 years now, including one with a 6 puck unsprung copper clutch (without a lightweight flywheel though).
When I got in the car, my wife came with me. After 5 minutes of driving, she said, "Take me home, I need a helmet to ride with you now."
After a week of driving it, I can pretty much so go without issues, except on an incline, where everyone seems to think they should pull up so close behind me that if I blew flames I could probably set their toupee on fire or move my seat back an inch and be sitting on their hood. Meh.
Pros:
Revs Like Mad
Pedal Feel is like stock... not heavy at all
No issues with 1-2 or any other high RPM shifts
No issues getting the car into R
Has great engagement and feel in upper rpm ranges
Cons:
Engagement is almost on off (not nearly as bad as a 6 puck), maybe 1-2"
It makes me look like a tool sometimes.
It rattles more than the stock even (exedy says it is absolutely normal)
Inclines are a biznitch when stopped on them.
The hardest part is training yourself how to deal with the studder when partially engaged. You have to let it out, but stock clutches you would want to give more gas or push in the clutch more. Do that with this clutch, and you will go nowhere (except maybe backwards when on an incline). I think part of it is adjusting to the lightweight flywheel as well.
Old Jan 21, 2008 | 12:31 AM
That's what keeps mine out of the car too..she doesn't like the bumpy ride and the roughness of the drivetrain. I love it !
Old Jan 21, 2008 | 09:15 AM
slavearm's Avatar
Boost Junkie
You also have Mazsport's solid mounts, don'tcha?
Yes... but that never was a problem before. It is actually much better now with the new bushings.
Old Jan 21, 2008 | 10:11 AM
tdiddy's Avatar
Finally Boosted!!!!!!!
I am at the point, without a lot of effort, where I can start smoother than I used to with the factory 'wheel and you can't even feel me shift gears most times.
Except on that 2-3 shift at WOT
Your mentioning the bushings reminds me of a PM I gotta send out........
I bet I know where that is going. Do you want his email? He checks it more often.
Old Jan 21, 2008 | 10:43 AM
tdiddy's Avatar
Yes, that ported renesis pulls just fine.
Old Jan 21, 2008 | 10:25 PM
Dang, after my install of the Centerforce Clutch and ACT prolite fly, it was much easier to shift than stock.
I can not comprehend how anyone could say it is a little harder and you have to get use to it.
Maybe I got the right set up fo me.
Old Jan 22, 2008 | 10:40 AM
Musker's Avatar
So it's easier to shift because the throttle response is faster? Or is it just the transition is smoother in the gearbox?
Old Jan 22, 2008 | 10:51 AM
staticlag's Avatar
The Professor
well, slavearm is using a full aluminum pressure plate and flywheel setup that probably has dual carbon friction disks and is half-size.
Aka, much lighter than any clutch flywheel combo that is "currently" available. Maybe 5-7 lbs lighter than a prolite & centerforce setup.
Centerforce with its extra heavy weight sort of counter-acts the positive effects of putting on a lightweight flywheel. The exchange is that you get great daily-drivability.
Old Jan 23, 2008 | 11:57 PM
SolarYellow510's Avatar
I had a Hyper Single in an RSX, lurved it. I've driven a Hyper Twin in an Evo, and it was also great. Have three friends with Hyper Twins in street-driven C5 Z06s, they all love them.
Haven't driven one on a rotary.
Old Jan 24, 2008 | 12:06 AM
slavearm's Avatar
Boost Junkie
It is getting better... or I am getting better. There is absolutely no comparison when it comes to high rpm shifts. This clutch pwns.
vapor2
May 4, 2020 03:53 AM
arexatemate
Oct 4, 2015 12:36 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
RXeckless
Aug 16, 2015 12:51 PM
