911! OBX Header and Turbo EX Exhaust! Help!
Old Jan 18, 2008 | 06:46 PM
DOMINION's Avatar
I don't buy Kool-Aid
Exclamation 911! OBX Header and Turbo EX Exhaust! Help!
I need to replace the gasket that connects from the header to the Turbo EX Exhaust with a mid pipe.
Anyone know where I can get one like right now? or ASAP!!!?
Also the O2 sensor will not come off of the OEM Exhaust Manifold
Anyinfo would be much kind!
PM me!
Thank you!
-Gilbert
Old Jan 18, 2008 | 06:55 PM
Gish's Avatar
Try Autozone or Pep Boys, any place like that.
Old Jan 18, 2008 | 06:56 PM
staticlag's Avatar
The Professor
are you talking about the donut one or the flat ring one?
you can just re-use both
Old Jan 18, 2008 | 07:06 PM
DOMINION's Avatar
Oh ok but what if you can cuz its all broken up.
And what about the 02 sensor? they cant get it off! and if I replace it, Its like $200 bucks! man this sucks.
Old Jan 18, 2008 | 07:10 PM
staticlag's Avatar
The Professor
take your time, if it is warm it might have trouble coming out, try a little WD40 but be careful to not get any on the sensor. My tool of choice for removing it is a adjustable wrench http://en.wikipedia.org/wiki/Image:A...ble_wrench.jpg
if its really stuck. try putting it outside in the cold to cool down for 20 minutes. Bring it into your garage and use a propane torch to heat the metal next to the sensor for a few seconds then try and take it off.
Old Jan 18, 2008 | 07:11 PM
staticlag's Avatar
The Professor
which one are we talking about, the flat thin ring gasket?
you can probably find that at autozone, pep boys, etc.
the fiber donut gasket you are probably going to have to buy from the dealership.
Old Jan 18, 2008 | 07:19 PM
DOMINION's Avatar
Ahh I see. But I dont know if they have tools like that.
Yeah I know I need to replace them. But thats ok.
Old Jan 18, 2008 | 07:21 PM
staticlag's Avatar
The Professor
a big vise grip might do it. be careful though
Old Jan 19, 2008 | 01:44 AM
DOMINION's Avatar
Our tech started working on the car at 10am till closing. and cant get it off. He tryed everything. Even what you said and still no dice. This sucks.
Can I do this as a option?
Buy a cheep O2 and run that for now so I can take off the Exhaust manifold with the OEM O2 and work on it latter?
This way you can still drive the car right?
Anyone know of a "O2 that will get the job done for now"? Just till I get the cash to buy the replacment OEM O2 sensor.
Thank you!
Old Jan 19, 2008 | 01:55 AM
NgoRX8's Avatar
mine is messed up to when i took it off the OEM manifold for my re-amemiya header. it took a lot of force to get it off, and the thread on the o2 sensor will get messed up.
not sure of any o2 sensor replacement for the exhaust manifold though. true the OEM one is expensive as hell.
Old Jan 19, 2008 | 01:59 AM
DOMINION's Avatar
I know Tanabe makes "a" O2 sensor but I dont know if they make one for our car or how much it is. I'm go google it. BRB...
Old Jan 19, 2008 | 02:11 AM
DOMINION's Avatar
Thats odd. I could not find anything on there sit but when I got my springs they had a add in a paper with my springs.
Old Jan 19, 2008 | 08:40 AM
tdiddy's Avatar
Finally Boosted!!!!!!!
A 22mm box wrench is what I used to get the front O2 sensor out. I needed to have the midpipe out of the car and it was a bitch. Heating it might help if penatrating oil doesn't help but don't heat the sensor directly. Heat the manifold around the sensor then try to remove the senso with the 22mm wrench.
Old Jan 20, 2008 | 10:45 AM
JB_Rotary's Avatar
Always lurking
PB Blaster
Old Jan 20, 2008 | 12:03 PM
Best thing to do is to buy another one for you midpipe...By the time you get it out...it won't work anyway....
Old Jan 20, 2008 | 03:41 PM
DOMINION's Avatar
^Sounds like you have done this before?
Old Jan 20, 2008 | 09:13 PM
Yep....I tend to comment on stupid things I've already done
Old Jan 20, 2008 | 09:47 PM
staticlag's Avatar
The Professor
Lol, reminds me of the safety steward of my last job at the pharm company...
"okay guys, the meeting today is about reaction safety, one thing you should NEVER do is throw a 5 gallon bucket of 50% sodium hydroxide into a tank of 80 degree celsius solution of pH 3. Why?
because when you throw the bucket in it reacts so violently it shoots back in your face and covers you with boiling caustic soda....
Old Jan 20, 2008 | 11:28 PM
DOMINION's Avatar
LOL thats classic!
Brokegang
Jan 3, 2016 12:45 PM
Rotary Swaps
Sep 21, 2015 04:52 PM
DVerdeyen
Sep 13, 2015 11:19 AM
