Replacing Alternator
Old Dec 22, 2007 | 04:52 PM
kimota's Avatar
Hello,
I'll be replacing my alternator with an Iraggi 220amp alternator after the new year. Are there any post detailing how to remove the alternator? I haven't been able to find one .
Any pics or info would be greatly appreciated.
Here's a link from another thread with some pricing info for Iraggi alternators for the RX8. I spoke with Dom from Iraggi alternators he builds these using the OEM RX8 alternator housing so it should be a direct bolt in.
Old Dec 22, 2007 | 06:04 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Originally Posted by kimota
Hello,
Wouldn't think it would be too bad. Loosen two bolts, move alternator, take belt off, remove electrical connector(s), remove all bolts(just a few of them), yank alternator and reverse proceedure to install new one. This assumes all mounting holes line up and same bolts will work.
Old Dec 23, 2007 | 05:30 AM
Its easy to do. Just look at ur service manual, it should take no more than 15 minutes. (assume u have all the tools)
Old Jan 2, 2008 | 12:38 PM
kimota's Avatar
Is there an online RX8 service manual? if so would you happen to have a link.
Old Jan 2, 2008 | 12:44 PM
HCTR154's Avatar
Go about half way down and you will see it.
http://foxed.ca/foxed/index.php?page=rx7manual#rx8
Old Jan 2, 2008 | 01:15 PM
kimota's Avatar
SWEET thanks HCTR154 definitely have to bookmark that page
Old Jan 2, 2008 | 03:54 PM
It would be better if u can just download all service manual.
Just in case one day that site goes offline.
Old Jan 4, 2008 | 10:13 AM
kimota's Avatar
You are wise , should be receiving the Iraggi 220amp alternator today. Hopefully I'll install it tommorow, thanks again for all the info.
Old Jan 4, 2008 | 10:30 AM
Remember to post pictures of *before* and *After* when u're done
cuz I wanna do mine too, I replaced my belt b4 so this is pretty much nothing new to me but ahh. I wanna see what the new alt. looks like
Old Feb 15, 2008 | 07:39 PM
u1cracka's Avatar
Did you install Your alternator yet I was thinking of getting a Iraggi 180 or 200amp but wanted to know how well it works with the RX-8.
Also how much did he charge for the alternator.
U1cracka
Old Mar 27, 2008 | 04:06 PM
kimota's Avatar
Sorry for the slow update the Irraggi alternators been installed for about 2 months with no issue. I ended having the dealer install it think they charged $135 for the install if memory serves me right.
I did attempt it myself gettng the belt of was a piece of cake but digggin a little deeper into the service manual I would have to remove the air intake system, and bumper to remove the alternator .
The Irraggi alternator was identical to the RX8 oem so it fit with no issue.
Old Mar 27, 2008 | 04:13 PM
HUH? Remove the Intake ???????
Well, u probably dont have the right tool to do it, I know I have K&N Ver II, but its no different in terms of removing the Alternator.
Edited : Oh, How is the 220amp Alternator ? Do u have lots of stuff in the car or something ?
Old Mar 28, 2008 | 03:00 PM
kimota's Avatar
The Alternators been great, I have a CarPC and After market Stereo with 2X amps.
Check out the links below they detail removing the alternator. The alternator looks like its easy to access but the bar that adjusts tension for the belt prevents you from easily removing the alternator without some major disassembly.
Check the link below and look at the instructions on changing the alternator they get pretty involved.
http://foxed.ca/rx7manual/2003mazdarx8/
If you look at the url rx7 is mentioned but on the webpage it list the manual as the RX8 which it actually is.
P.S
What is that GOD like burger you use for an avatar?
Old Nov 7, 2009 | 12:25 PM
elysium19's Avatar
(I know this is an old thread, but I have some experience to share about this)
1) Definitely get a copy of the service manual- it's not needed, but it's helpful just so you know which bolts you do and no not need to remove
2) You do NOT need to remove any part of the intake system, even though it says you do in the manual.
3) You DO need to remove the long curved black metal piece that the tensioner bolt connects to. (3x 12mm nuts) And to get to two of those bolts holding that black piece on, you need to remove a pulley lower down, which was 3x 10mm I believe.
4) I bought a used alternator and needed to swap out the pulley. I don't know if new alternators come with the pulley or not, I'd guess not. THIS WAS A HUGE PAIN IN THE *** because the main bolt (24mm I think?) was on so tight from the factory, AND when you try to turn it the alternator internals turn as well, so you can't exert torque on it. We needed to wedge some steel screwdrivers into the thing to "lock" it while turning the nut with a breaker bar. This, however, destroyed the internals really badly; I'm sure there's a way, but I have no idea how you could get this pulley off without destroying it in the process.
5) It took us 2 hours total.
6) The belt tension is a guessing game. I marked the tensioner bolt before I removed it, but I have a feeling some things changed because it seemed way too tight when Iput it back together. So- don't rely on markings and try to set the right tension from scratch, though this is hard without a special tool.
Old Nov 7, 2009 | 01:33 PM
Impact gun for the pulley bolt.....hold the pulley with a strap wrench and hit it with the impact and it will come right off...
You don't want to stick anything inside the case on an alternator if you ever want to use it again
Old Nov 7, 2009 | 11:08 PM
elysium19's Avatar
HAHA I need to get a photo of it- there are FIVE THICK STEEL allen wrenches that are all BENT and un-removable from the thing! That alternator doesnt have a hope in hell of working, and I dont have a hope of getting my keys back!
Old Nov 8, 2009 | 07:28 PM
just about any tool rental place carries a 120V impact gun, or go buy one at Home Depot etc.
you can hold the pulley with a gloved hand, the impact action knocks the nut off easily
Old Feb 5, 2011 | 08:02 PM
OptimismNeverFails's Avatar
Arbuckle
Torque required for alternator pulley??
I'm getting ready to replace my stock pullies with the Greddy kit, and was wondering if anybody is aware of the torque required on the main alternator bolt. Any response would be greatly appreciated, as I am performing this in a couple weeks. Alos, a response with a link to a website is also accepted.
Thank you
Old Feb 26, 2011 | 07:59 PM
Arbuckle
Nevermind... Found the torque required. Website is this: http://isomerica.net/~fluffy/Ren/RX8%20FSM/
Click on the 4th index (3EngineDetails.pdf) and go about 3/4 down the page. The generator install/battery install are in the same section.
Torque/bolt size is listed as follows:
Alternator Pulley: 72.3-101.0 ft. lbs/24mm stock bolt
Eccentric Pulley: 10-12 ft. lbs/10mm stock bolt, 5mm hex/allen bolt for Agency Power Pulley
Water Pump Pulley: 69.1-95.5 in. lbs (converts to 5.8-7.9 ft. lbs)/5mm Greddy Pulley bolts
Old Feb 18, 2012 | 07:07 PM
aruffell's Avatar
Sorry for responding to an old thread but I found this thread to be useful when trying to replace my alternator, or rather "generator" (although the RX8 service manuals occasionally call it an alternator, the majority of the references are made as generator controlled by PCM).
I did not remove the air intake system to get the alternator out, and I did not take the pulley off either (the one that blockes the nuts to the black tensioner bar). All I did was remove the two bolts on the top used to regulate the tension, the vertical nut half way down the black bar, and then totally loosened the two nuts behind the pulley with a 12mm wrench. the black bar can now move towards you enough to remove the alternator without having to remove it completely.
Of course you have to remove the bar that crosses the entire engine compartment, and disconnect a rubber tube connected between the oil knozzle and the air intake system - just disconnect one side and move it out the way.
This is the first time I replace an alternator and it took me just over an hour as I reduced what I had to do as much as possible.
I am hoping that replacing the generator will stop the alt light from comming on randomly at low revs or during city driving.
Hope this helps others!
Old Feb 15, 2014 | 01:10 PM
robobxman's Avatar
Ok, I just went through this also. First of all, I chose to have a local guy rebuild my alternator instead of buy a reman via autozone or advance. Smart choice; he did a great job for $140. He said those reman'd alternators are crap and he often refuses to rebuild them.
Anyway, a few thoughts about the alternator replacement:
- You don't need to take off the black bracket. You do have to loosen it like elysium recommends. But it's worth loosening the air intake hose between the air filter housing and intake, and turning it to the right. You also have to remove a couple air hoses that connect to it. This buys you about 3/4" clearance, and you will need it all.
- Change your belts while you are at it; it's much easier to do this without the alternator in your way.
Otherwise, it's a pretty straightforward job.
Old May 2, 2014 | 11:02 PM
Cesarcigala's Avatar
Rotary Vegas
Hey guys, I am having trouble removing the alternator pulley. I tried holding the pulley with a strap wrench but it s pretty hard and I don't want to push it harder cuz I am afraid to damage something. I heard that using an impact wrench is not a good idea. does it come off clockwise? or counterclockwise?
Old May 2, 2014 | 11:05 PM
impact is fine.......
Old May 2, 2014 | 11:06 PM
lefty loosey
Old May 3, 2014 | 02:51 AM
Rotary Vegas
That Worked. Held it tigh with strap wrench and impact wrench
