Which Tyre shop does Alignment (wf castor measurement)
Old Dec 17, 2007 | 08:18 PM
rx8dorifto's Avatar
Hi bro,
Anyone know which shop can do good alignment with castor measurement?
Recently changed my spring, the castor a bit off. Did my alignment in a lousy tyre shop which measure the castor using his finger!
After the alignment, still feel my steering a bit weird especially in HDB parking up slope, the steering wont rotate back to center as normal in slow speed. So, I think my castor is really off.
Appreciate if anyone can let me know where can measure the castor angle WITH some sort of device.
Thanks in advanced.
Old Dec 17, 2007 | 10:04 PM
lennon's Avatar
Check your tyre pressure first b4 do alignment..... Many people doesn't care about this, so does the tyre shop....
Old Dec 17, 2007 | 10:17 PM
lone_wolf025's Avatar
Future Rotary User
Any reputable alignment shop can do castor.
Old Dec 17, 2007 | 10:18 PM
rx8dorifto's Avatar
i did. 230psi all round.
the 1 last thing i can think of is the castor...which normal tyre shop can't measure.
Old Dec 18, 2007 | 08:32 PM
sandman369's Avatar
think most with those electronic alignment sys can measure caster.
try kenny wheel alignment at AMK autopoint 4th floor. call to book appointment before going. 90921015
Old Dec 19, 2007 | 12:34 AM
rx8dorifto's Avatar
thanks man
Old Dec 23, 2007 | 12:39 PM
wildchilde's Avatar
Or you could try Riverview at AMK autopoint as well. Several peeps I know (not 8 drivers though) go there for alignment.
Old Dec 23, 2007 | 07:28 PM
rx8dorifto's Avatar
scheduled an appointment with kenny aldy...1 long week wait for the appt!
thanks for all your helps man! I got to keep all these workshop contact in my database.
Old Dec 23, 2007 | 09:48 PM
sandman369's Avatar
ya it's worth the wait. you should explain your problem and preferences to him, and he should be able to give good advises.
Old Dec 23, 2007 | 10:37 PM
rx8dorifto's Avatar
yup...found a recommended wheel alignment spec in this forum. But a bit confused, the recommended camber seems too much:
Front Camber: -0`45' (was told that normal camber is -0`20')
Front Toe: -1.1mm
Castor: +6`41'
Rear Camber: -1`44' (isn't this too much for tire wear?)
Rear Toe: +1.7mm (toe out???)
attached with the recommended spec, please let me know that I should follow them. thanks
Attached Thumbnails Which Tyre shop does Alignment (wf castor measurement)-alignment.jpg
Old Dec 25, 2007 | 07:36 PM
sandman369's Avatar
Front Toe: -1.1mm
Castor: +6`41'
ok I must first clarify I'm no expert on alignment settings for the 8.
I would normally talk to kenny abt what i want and how i feel so that he can make adjustments. kenny has a few settings for the 8 so you can refer to them. on the figures above, think they look ok. +ve toe means toe-in, so it's ok, slight toe-out in the front and toe-in in the rear (for better turn-in). too much toe can cause tire wear so apply sparingly. the camber settings look ok too. think i'm using -1.5' (ie 1' 30") for the rear. camber settings depends on the vehicle height. with car lowered, think can go until 2' for more agressive settings. for stock, dun go beyond 1'.
Old Dec 26, 2007 | 01:39 AM
rx8dorifto's Avatar
i got Tein H tech on my ride. But afraid that -1.5' is a bit too much as I dont go track that often.
Think I'll set at -1' first, when going to track then increase it.
Azki23
Jun 27, 2018 03:48 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
duworm
Oct 1, 2015 04:57 PM
