Help!!!! Running Bad....
Old Nov 15, 2007 | 08:36 PM
turbo'd8's Avatar
Tulsa,ok
Exclamation Help!!!! Running Bad....
hey guys i need help my 8 is running really bad. it ideals fine but when i give it throttle while in neutral its slow to respond and it wont go past 4-5k rpms. and when ever i drive it its real ruff and it doesn't want to accelerate.
there doesn't seem to be any vacuum leaks that i could find. and when it started this i was driving home from work and started noticing a whistle like a air vac. leak or something. so i drove it home and back to work like that,but before i got to work it started getting worse i would floor it and it wouldn't go anywhere and the whistle got louder. i have no idea where to start to fix this thing. i really need some advise. please help i have to get this fixed as fast as possible. im without a car.......
thanks,
turbo'd8
Old Nov 15, 2007 | 09:26 PM
AllMyDiamonds's Avatar
AllMyDiamonds
You should have a compression test done, but it could be a list of things (motor mounts, coils, gas, etc.) You still have it under warranty, right?
Old Nov 15, 2007 | 10:18 PM
Is your car really turboed ?
If yes and you're using Stock Greddy kit, check the hose, its a KNOWN weak spot. Also, remember Tune it.
If Stock N/A form, check 3 plastic tube that goes around the intake manifold and SSV tube for leaks.
Old Nov 16, 2007 | 05:44 PM
turbo'd8's Avatar
Tulsa,ok
ok ill check those things, thanks guys and if any one can think of any thing else let me know.
Old Nov 16, 2007 | 06:41 PM
Bad cat?
RevMeHarder
Jun 1, 2026 02:30 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
yapakanichi
20
Sep 10, 2015 07:17 AM
