better handling
Old Oct 26, 2007 | 01:33 PM
alleycatinheaven's Avatar
Talking better handling
ok, i'm not a mechanic nor engineer. i have a good foundation of basic automobile configuration. i autocrossed my car several months ago. only upgrade was 245 falken 615's. other than a m3 i was fastest in my class. the most difficult areas and where i lost the most time was in the slalom sections. i let my daughter drive in this most recent cross and watched from the sideline. in the slalom the front end lifts off like an f16. i would like to reduce the roll but i'm not into rebuilding the suspension. anything i do will mean i buy the parts and pay a shop to install. at the same time, if there was one visual i'd love to see, that would be the car lowered. so, would the best bang for my buck be to purchase a set of lowering springs and have them installed. please keep in mind that i DO want to reduce body roll, i DO want to have the car lower, and I am willing to compremise SOME on the street ride, although the 911 and 350 are both a little stiffer than i would like. suggestions please? also, if you could recommend the make and model of the springs that would be most helpful. i'd like to complete this project before the next cross (3 weeks). thanks!!!!
Old Oct 26, 2007 | 02:12 PM
zerobio's Avatar
Atomic 8
All I know is "springs", eibach, teins, swift, I think they're all pretty good but I prefer eibach. Don't have the tech background to answer better. Good luck.
Old Oct 26, 2007 | 03:33 PM
mikesol's Avatar
gas kilometerage
How about a front skirt of some kind to prevent front lifting?
Old Oct 26, 2007 | 04:16 PM
StewC625's Avatar
Insanely Yellow
Was going to say Tien and Eibach, but also was going to say ...
SEARCH!!!!
Old Oct 26, 2007 | 04:21 PM
paulmasoner's Avatar
Asshole for hire
are you serious? a front skirt gonna help prevent lifting at autocross speeds??? you must be on crack
Old Oct 26, 2007 | 04:22 PM
Spinning Sushi's Avatar
I <3 Sushi
^lol! might as well just glue weights to your front
Old Oct 26, 2007 | 04:57 PM
Go48's Avatar
Best bang for the buck to reduce body roll probably would be a set of good aftermarket anti-roll (aka, anti-sway bars, panhard bars) bars. I have the Racing Beat bars on my RX-8 and it makes a noticable difference in body roll and steering precision/quickness.
Old Oct 26, 2007 | 10:12 PM
correct.
Old Oct 26, 2007 | 10:18 PM
TheKDog's Avatar
2007 BB RX8 GT
Exclamation
You can't improve the RX8's handling.
It's impossible.
Old Oct 29, 2007 | 06:39 PM
would the new anti-sways effect the ride quality straightline?
Old Oct 29, 2007 | 07:01 PM
Go48's Avatar
Not that you could notice. At least that's my experience with the RB bars.
Old Oct 29, 2007 | 07:06 PM
shaunv74's Avatar
Power!!
I would go with the full Racing Beat setup. Sways, Springs, and Koni Shocks. This will give you all of what you are looking for.
Beware that the new Swaybars and springs may put you in a different autocross class.
www.racingbeat.com
Old Oct 29, 2007 | 07:10 PM
WoodsOfGreenRx8's Avatar
Sway bars are a great option! Check in the suspension section. Funny to see your from Redding, since I graduated from Foothill HS there.
Old Oct 29, 2007 | 07:51 PM
Paul_in_DC's Avatar
Rotary Public
I had great results when I went with the Tokico shocks. Much less roll, and easy to adjust for autox versus street setup.
Old Oct 30, 2007 | 07:46 AM
chetrickerman's Avatar
If you want zero body roll, go with the progressauto.com sway bars.
Old Oct 30, 2007 | 08:08 AM
1stgenchevy's Avatar
Completly agree, Just to make sure you stay in the same class, you may want to try just an upgraded front swaybar, and maybe the thicker endlinks from racing beat. If that doesn't get rid of most of the roll you may want to try an ungraded strut bar(or what ever you want to call it)
If your not getting too much roll from the back of the car I wouldn't mess with the rear swaybar unless you need to.
Old Oct 30, 2007 | 10:14 AM
well i would think it would be good to replace the rear sway bar also, seeing as there is weight back there too. That would further reduce the body roll and help handling.
Michael Bryant
Oct 12, 2015 03:07 PM
JAYDOH
Sep 24, 2015 01:54 PM
doc.tarzan
Non-Rotary Swaps
Sep 24, 2015 08:32 AM
Hunter of Gunmen
Sep 21, 2015 06:27 PM
