245/45 R18 w/ stock rims O.K. on the front???
Old Sep 22, 2007 | 08:12 AM
wilmic44's Avatar
Will this not rub?
Old Sep 22, 2007 | 10:39 AM
Rotor Kreuzer's Avatar
The 8th Deadly Sin
Nope. Have this set up on mine all round for a year and a half now with no problems. It was by mistake though, and I wouldn't do it again because it does raise the car slightly, which is especially evident at the front. I'd recommend going with 245/40s instead.
Old Sep 22, 2007 | 10:53 AM
G-ReX's Avatar
A Torque-Free Zone
I have 245/40 R18's and there's no problems at all on stock rims. It's very close to stock size, so there's negligible speedo error (<2mph low at indicated 72 mph based on a couple GPS's, and some of that is baseline error). Pic shows mine on the right, stock on the left, just for a visual.
Old Sep 22, 2007 | 01:19 PM
titaniumgr3y's Avatar
JDM-8
it raise the car by 2.5cm!
if you really want to replace stock's size with wider tire, make it 245/40R18, it will lower the car by 0.4cm(4mm) which is really nothing, it keeps your 8 in stock height. A lot of us done it and from my personal experience they feel great.
Old Sep 22, 2007 | 02:29 PM
987HYS's Avatar
Dragon Certified
They will fit, just remember the wider you go the less steering response you will have. You will have more grip but the car won't be as responsive to your steering inputs. It all depends on what kind of driving you want to be doing.
Why do you want to go wider anyway?
Old Sep 22, 2007 | 02:50 PM
Spin9k's Avatar
Momentum Keeps Me Going
Perhaps you need to re-think that idea 987.... or drive a car with wider tires to understand.... or did you mean to say taller?
Old Sep 22, 2007 | 04:29 PM
G-ReX's Avatar
A Torque-Free Zone
I didn't notice any loss in steering response going from the OEM 040's to slightly wider 050 Pole Positions. The tires really feel the same to me; the only real difference is a marked reduction in road roar (and hooray for that). I was shooting for a more grip with the extra width, but I never pushed the car with the OEM's like I did with the new tires at the Dragon, so I couldn't tell if it was better. Gas mileage has been the same as well, despite a little more rolling resistance with wider tires.
Old Sep 22, 2007 | 04:34 PM
wilmic44's Avatar
well, to be honest with you all. When I recently purchased the 8 the dealer had brand new tires on the back, which are 245/45 R18. The front tires are pretty much shot. So, I then purchased the exact same tires that are on the back so that I can rotate from front to back. I just want to make sure that these tires will not rub or cause any problems before I have them mounted. Next Wed. I am having them mounted and balanced along with a 4 wheel alignment. Within the next couple weeks I plan to take the 8 to the dealership to have them look it over good and let me know if it needs any ecu updates or recalls. Any info or advice is welcomed.
Thanks,
Mike
Old Sep 22, 2007 | 04:42 PM
dillsrotary's Avatar
jersey fresh
go with 245/40, you'll be fine, i have that on all four and i'm lowered pretty low.
kondypl
Jul 4, 2011 06:47 AM
HUSSAIN
23
Nov 17, 2008 09:43 AM
Hesselrode
11
Nov 27, 2007 05:24 PM
wilmic44
Sep 21, 2007 10:32 AM
quickice4
Aug 13, 2007 06:01 PM
