Compression ratios?
Old Sep 18, 2007 | 05:21 PM
ashwins's Avatar
Question Compression ratios?
Anybody knows what is the typical compression ratio of an rx-8 rotary engine? How are the rotary engines tested ?
Old Sep 18, 2007 | 05:41 PM
See the Picture.
and read the Service Manual.
Old Sep 19, 2007 | 08:34 AM
champi0n's Avatar
I think its 10:1? or something... and they'd be tested the same way as another car, the guage is screwed into a spark plug hole.
Old Sep 19, 2007 | 09:01 AM
*sigh* ...
Old Sep 19, 2007 | 10:03 AM
ashwins's Avatar
what is the safe level of variance? I read somewhere else that a compression ratio of 7 meant that the engine is dying?
Old Sep 19, 2007 | 10:06 AM
tajabaho1's Avatar
Destroying Threads
?? I read somewhere on this forum its 9.4:1?
Old Sep 19, 2007 | 11:32 AM
Joe_914's Avatar
This is just too easy I couldn't pass it up.
the static compression ratio be it 9.4:1 or 10:1 has absolutely no relation to the numbers you get from conducting a compression test with a gauge in the spark plug hole and rolling the motor over with the starter.
Azki23
Jun 27, 2018 03:48 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Vedivan1
Sep 18, 2015 12:39 PM
