04 Dyno Results
Old Sep 8, 2007 | 11:36 AM
BranDaMan's Avatar
04 Dyno Results
I just got my 04 6mt 8 dynoed this morning and I wasn't very impressed but I wasn't disappointed either. My only mods are K&N short ram intake and Racing Beat Cat Back. I dont have a scanner so i cant post the graphs. sorry maybe when i get to school monday i can post them up...but here are the numbers...
179.2whp
135.9wtq
And my air/fuel ratio was hoovering around 12 which i think is normal.
The guy doing the dyno told me that he had done a stock 04 6mt a few months back and he got...
171.9whp
132.2wtq
So i figure i picked up about 8 whp with my mods. Not great but I guess pretty normal for the 8.
So do my numbers sound about right? The guy doing the dyno said he could tell that i needed new plugs and wires by how the car was pulling on the dyno.
Which is true b/c im at about 27400 miles and im still on my first set, i was planning on changing at the 30k maintenance. Im pretty sure i'll pick up a few hp from the new plugs and wires.
Old Sep 8, 2007 | 12:27 PM
What brand of dyno? Makes a difference ...
Old Sep 8, 2007 | 12:42 PM
BranDaMan's Avatar
DynoJet
Old Sep 8, 2007 | 04:47 PM
124Spider's Avatar
Corrected or uncorrected (for atmospheric pressure, temperature and humidity)? Uncorrected numbers are virtually useless (even more useless than corrected numbers from different dynos at different times).
Old Sep 8, 2007 | 11:15 PM
BranDaMan's Avatar
sure...about 85 degrees and it was pretty humid.
Old Sep 8, 2007 | 11:56 PM
124Spider's Avatar
They should have given you raw numbers, and numbers showing the equivalent for the standard temperature, pressure and humidity. Giving you uncorrected (raw) numbers, without normalizing for variables, is essentially worthless.
Old Sep 9, 2007 | 11:35 AM
Mustang and Dynojets usually display corrected numbers
Dynojets usually indicate about 10% higher than a Mustang, but all dynos are not created equal as even within the same brand/model there are slight differences in indicated outputs
https://www.rx8club.com/showpost.php...&postcount=229
Old Sep 9, 2007 | 12:52 PM
124Spider's Avatar
The printout for a Dynojet will say whether it's corrected or uncorrected.
Old Sep 9, 2007 | 06:25 PM
olddragger's Avatar
youre car is fine man--new coil and plugs could possibly give you 10-20 more hp on the top end.
olddragger
Old Sep 9, 2007 | 06:30 PM
joshk118's Avatar
olddragger
are you serious? 10 to 20 hp from a coil and plugs? my car is at 49k miles, would i get those results from replacing my ignition system components? im talkin about a new coil, new wires, and new plugs
Old Sep 9, 2007 | 06:35 PM
Brettus's Avatar
Boosted Kiwi
agree with OD if your peak hp is way below 8500 - that it is most likely a coils problem
Old Sep 9, 2007 | 06:43 PM
olddragger's Avatar
yep-it has been shown many times.
OD
Old Sep 9, 2007 | 10:04 PM
AcidAngel7477's Avatar
Once Again..
where did you get it dyno'ed?
:AA:
Old Sep 9, 2007 | 10:58 PM
olddragger
pretty bold prediction given the lack of data to support it
Old Sep 9, 2007 | 11:48 PM
dmp's Avatar
dmp
RX8 and a Truk....
179.2whp
135.9wtq
171.9whp
132.2wtq
There's no way you know if your mods made ANY HP. without a baseline run of YOUR car, there's a chance your mods REDUCED Your HP.
MY Car, on a dynojet, stock, made 186whp. That'd mean your mods 'cost' you a few ponies.
Get what I mean?
Old Sep 10, 2007 | 11:00 AM
BranDaMan's Avatar
:AA:
Colvin Automotive Austin Tx
Old Sep 10, 2007 | 11:04 AM
BranDaMan's Avatar
Get what I mean?
I was just making a PREDICTION since both cars were dynoed at the same place and were same year and had almost same mileage. Mine only with RB exhaust and K&N Intake. Maybe they did make me lose 7 whp.
Old Sep 10, 2007 | 02:01 PM
dmp's Avatar
dmp
RX8 and a Truk....
I know it's a 'prediction' but what I'm saying is 'Don't predict if you're worried about accuracy.'
I've seen 7-10hp difference between like cars, on the same dyno, on the same day. That's all.
As far as the RB Exhaust? Count/hope-for 1-4hp, peak, gain. For the K&N? I think you'd actually be lucky to have not lost power. Not hatin'...just from my experience reading the forums.
Regards.
05rx8mazda
Nov 28, 2015 09:42 AM
BERG
Oct 8, 2015 09:28 PM
ErwinN
Sep 23, 2015 09:29 PM
rxwilly8
Sep 2, 2015 02:42 PM
