View Poll Results: What octane level do you use?
87 - Regular
13.04%
89 - Plus
6.52%
91 - Premium
19
41.30%
93 - Super
18
39.13%
Voters: 46. You may not vote on this poll
What octane do you use?
Old Oct 10, 2003 | 10:33 AM
Slice's Avatar
Althought premium is recommended, what octane do you use?
Old Oct 10, 2003 | 10:40 AM
8_wannabe's Avatar
Go baby!
Re: What octane do you use?
For optimum performance (meaning max hp) 91 octane is recommended. Anything above 87 is ok. You will lose a little performance with 87, but will not hurt the engine nor diminish gas mileage.
Let the purist rants begin, as per the umpteen other threads on octane.
Old Oct 10, 2003 | 02:05 PM
U. N. O.'s Avatar
who?!
i am ussing 87 right now, i wish i had 91 around here but it goes from 87-89-93 ($.20 cheaper).. well you know i wish we had it like in europe 98 oc.!! as super and 95 as regular..
edit.: there is a "sheetz" gas station that has 91 but it is way too far..
Old Oct 10, 2003 | 02:11 PM
mikeb's Avatar
100% Italian
I use 91 and feel safe with that
Old Oct 10, 2003 | 02:13 PM
RX-GR8's Avatar
Originally posted by U. N. O.
i am ussing 87 right now, i wish i had 91 around here but it goes from 87-89-93 ($.20 cheaper).. well you know i guess we had it like in europe 98 oc.!! as super and 95 as regular..
same here. 87-89-93. ive been using 93 but i may try 89 for awhile. if there arent any problems ill stick with 89.
Old Oct 10, 2003 | 02:17 PM
U. N. O.'s Avatar
who?!
i will be nothing wrong.. i might "upgrade" to 89 after a couple of tanks more once the prices go down again..
Old Oct 10, 2003 | 04:36 PM
allstate's Avatar
Contents Extremely Hot
93 here...I might downgrade to 91 for a tank and test it out.
Old Oct 10, 2003 | 05:33 PM
ptiemann's Avatar
As far as I remember in Europe - or Germany - the lowest you can buy is 91. They measure the Octane somehow different.
Europe 91 "regular" = USA 87
Europe 95 "super" ... 91
Europe 98 "super plus" .. 93
They even have 100 now.. which probably corresponds the the 95 sold in the USA.
-Peter
Old Oct 10, 2003 | 08:56 PM
come 8 me's Avatar
93 always
Old Oct 10, 2003 | 09:52 PM
sjt's Avatar
sjt
look MA! No PISTONS!!!!
Anyone tried 'race' gas yet???
100-114 octane???
Old Oct 11, 2003 | 06:38 AM
6speed8's Avatar
I would be careful with which Octane you use. The way I always usnderstood it was the higher the octane, the SLOWER the burn of the fuel mixture. The lower the octane the FASTER the burn. If the fuel mixture burns too fast, damage to the engine can occur, and if the mixture burns too slow, you will waste gas, overload the catyalytic converter and actually hurt performance. And there are other issues as well including heat.
For a simplistic overview check out this explanation:
http://www.cruzers.com/~twakeman/LR/FAQ_octane.htm
Old Oct 11, 2003 | 01:14 PM
U. N. O.'s Avatar
who?!
-Peter
how is octanage calculated? do you know? well its the same here as there. the only diference is that there is counted by the litter while here is by the gallon..
Old Oct 11, 2003 | 04:14 PM
takahashi's Avatar
yeah Why there is different units????
I knew that the one use in Australia is RON... we have 98, 95 and 91 RON.
Add fuel additive even get over 102 RON
Sure it will be more responsive for the 8 as a high rev engine should benefit with more RON!
RevMeHarder
Jun 1, 2026 02:30 PM
OnebaddRx8
Aug 25, 2019 11:34 PM
Modern2Strokez
Aug 16, 2015 01:07 AM
CMRine04
Jul 29, 2015 02:07 PM
Belalnabi
Jul 17, 2015 07:48 PM
