please verify
Old Oct 8, 2003 | 09:02 PM
come 8 me's Avatar
please verify
I have the boss system in my 8,i just looked in the trunk, I notice there are no marking of the name boss on the speakers only numbers and letters. are these real boss have anyone notice or is this old news.
Old Oct 8, 2003 | 09:10 PM
Tamas's Avatar
Registered Lunatic
<smartass mode>
Unless good ole Hugo is making now car stereo systems instead of suits, you sure shouldn't have any Boss markings on your speakers. Rather Bose. :p
</smartass mode>
Old Oct 8, 2003 | 09:47 PM
come 8 me's Avatar
hahahah did i say bossi maen bose
no bose either.
Old Oct 9, 2003 | 01:55 AM
mikeb's Avatar
100% Italian
that would be BS if they arent
mazda would be in so much heat if they werent bose
Old Oct 9, 2003 | 02:04 AM
Squidward's Avatar
Bottom feeder
is this the same car that came with the particle accelerator sticking out the back??
Old Oct 10, 2003 | 11:53 AM
Kap's Avatar
Kap
If you take off the grill/cover, you will see 'Bose' in tiny letters embossed onto the cone of the speaker itself. It is present on the 6X9's and the 9 inch woofers.
Old Oct 10, 2003 | 03:06 PM
mikeb's Avatar
100% Italian
thanks kap
Old Oct 10, 2003 | 10:15 PM
come 8 me's Avatar
thank you
i was looking at magnet side of the speaker.
I feel better now
Old Oct 10, 2003 | 10:42 PM
Kev's Avatar
Kev
[rapidus octus]
Hey Kap, seeing you've been there...
Did you go as far as taking the 9's out to look?
I'm interested in the depth available and the way they're mounted, real size of the hole, etc.
Plus there's an amp in there isn't there? Do you know if it's part of the speaker assembly itself?
Old Oct 11, 2003 | 12:30 AM
Kap's Avatar
Kap
I didn't do any of the work myself (as I know zilch about car audio). I'm having a shop replace all the speakers for me, but I am looking over his shoulder at times trying to understand what's what. But I'll try to answer your question best I can understand.
The actual size of the hole in the door is 9 inches. It's actually a circular trim that gets raised away from the door panel a little. I can imagine putting a 9" circular cutting board about 3 inches thick into the hole and have it flush. The mounting depth looks fairly deep as the bottom right corner of the driver's side window only intrudes into the speaker hole about 2 inches. That means you can go all the way to the outer panel in depth. Just from a glance, it looks like you have a bit over 3 inches to work with. The woofer isn't mounted in any special way, just a couple of screws (I think 4) on top of the woofer to secure it to the holes in the panel.
I'm not sure if what I saw was an amp, it seemed more like a crossover as it was a rectangular box about 2" x 4" that had a signal cable coming in from the head unit and one set of cables going up to the tweeter and another set going to the woofer. There's definately nothing attached directly to the speaker besides it's own magnet.
Anyhow, I hope that gives you some idea of how things are behind that door panel.
Old Oct 11, 2003 | 02:04 AM
Dugless's Avatar
Those are the door amps. And most of the time, Bose doesn't actually manufacture the speakers, they more or less specialize in enclosures and getting the most out of a "plain" speaker. They have various suppliers.
Warrior777
Jun 24, 2019 04:47 PM
drebbrnator
Dec 27, 2018 07:02 PM
OnebaddRx8
Oct 17, 2015 10:05 PM
RXeckless
Aug 16, 2015 12:51 PM
