Arrrg! Electrical Problems!
Old Oct 8, 2003 | 06:06 PM
HaroldDog's Avatar
My engine light goes on AND the immobilization warning light (flashing red car/key thing) flashes when I turn and remove the key.
It is STILL flashing!
Taking it in (25 miles away) tomorrow.
Any insights? This kind of thing happaned with my TT and they had to replace the entire dashboard cluster.
Sigh.
Old Oct 8, 2003 | 06:17 PM
Kap's Avatar
Kap
Yikes, sorry to hear about your troubles. Sounds like your jinxed when it comes to new cars.
Old Oct 8, 2003 | 06:20 PM
Slice's Avatar
UGH! Be very careful; call Mazda (or dealer) see if they have any insight. I wouldn't want to hurt the car....my 2 cents...
Old Oct 8, 2003 | 07:48 PM
eccles's Avatar
Prodigal Wankler
Re: Arrrg! Electrical Problems!
The CEL (engine light) indicates a problem with the system somewhere, not necessarily an electrical problem in the dash. The dealer will be able to read the code and identify the problem.
But the flashing red car when remove the key is quite normal - it's supposed to do that, to indicate that the system is armed!
Old Oct 8, 2003 | 08:07 PM
RX-GR8's Avatar
yes mine flashes too when the key is removed. it's normal! as far as the cel remove the gas cap and put it back on and turn it 4 clicks. worth a shot.
Old Oct 8, 2003 | 08:10 PM
the CEL is probaly the gas cap pr some other easily fixed problem. the flashing car should not continue to flash if you insert the key and turn it. if it does then that might be what caused the CEL. it always flashes when the key is removed. is the key you are using the one with black plastic or the one with the grey plastic?
Old Oct 9, 2003 | 09:51 AM
MyRxBad's Avatar
Fb's rock!
"Read the Manual" :shrug:
Old Oct 9, 2003 | 07:48 PM
mikeb's Avatar
100% Italian
harolddog
did you figure it out yet
Old Oct 18, 2003 | 02:54 PM
syntrix's Avatar
I like cheese!
Hmmm, I just got to the ecu, and noticed about 3 wires that were crushed between the plastic housing.
They did do that at port, right?
Forutunately nothing is wrong with mine, but might be a place to check the connectors, etc.
Old Oct 18, 2003 | 07:13 PM
HaroldDog's Avatar
Solved
I am all set. They said that a signal from the thermostat tripped the warning light.
They reloaded the computer info and everything is fine. the car never ran hot.
Apparently just a computer glitch.
yurcivicsux
192
Sep 12, 2017 10:54 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
zoom44
General Automotive
10
Sep 29, 2015 09:56 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
Vedivan1
Sep 18, 2015 12:39 PM
