Oil Plug Pics
Old Aug 6, 2007 | 10:52 AM
Blacknoir's Avatar
6SPDUFO
Oil Plug Pics
Anyone have a decent shot of where the oil plug is? I looked at the ones in the DIY post but they're not very good. I'm planning on changing my oil tonight for the first time and just want to be sure i can find the dang thing.
Thanks,
BlackNoir
Old Aug 6, 2007 | 11:51 AM
costello's Avatar
It might be hard to tell from pictures where things are located because photos don't always show a wide field of view.
For the engine oil drain plug, look under the car from behind the front passenger side wheel. It's on the side of the oil pan.
Old Aug 6, 2007 | 12:08 PM
Blacknoir's Avatar
6SPDUFO
Is this it?
Old Aug 6, 2007 | 12:12 PM
savedsol's Avatar
Carbonormous
Well you circled about three bolts there. It's the black one your circled.
Old Aug 6, 2007 | 12:31 PM
Yes......sure you want to change your own oil?
Old Aug 6, 2007 | 03:19 PM
Blacknoir's Avatar
6SPDUFO
ah man, cut me some slack here.. at least I'm trying..
Old Aug 6, 2007 | 05:12 PM
Come on...you gotta admit the dig was just there for the taking
Old Aug 6, 2007 | 05:54 PM
Brettus's Avatar
Boosted Kiwi
new stuff goes in at the top - but put the plug back in first eh !
he he
Old Aug 6, 2007 | 08:55 PM
staticlag's Avatar
The Professor
actually, before you even remove the oil, you want to "try" and get the OEM filter off first.
Nothing sucks like an engine with no oil in it and no way to change the filter.
Old Aug 6, 2007 | 09:18 PM
olddragger's Avatar
kudo's for willing to start man---its a learning curve and we all have been there.
Remember dont tighten the dang drain pug to tight when you reinstall. Put rags under your filter to catch the oil that will drain out when you get it loose. Dont pour the oil in too fast and use a long neck funnel to pour it in with. the oil can back up while poring and some dont notice that it can run down the little vacuum tube to the intake=not good.
olddragger
Old Aug 6, 2007 | 09:19 PM
olddragger's Avatar
oh by the way he can post a picture on the forum and i still havent firgued out how.
olddragger
Old Aug 6, 2007 | 09:57 PM
woodysjh's Avatar
I already searched!!!!!!!
Make sure you check the oil filter to see if you can loosen it before doing anything, I had to tow my car to the dealer because I couldn't get the oil filter loose. I shoved a screw driver through it to try to twist it off and it still wouldn't come loose.
Old Aug 6, 2007 | 10:39 PM
DrewMan's Avatar
Culpam Poena Premit Comes
i think the best way to get at it is from underneath with a long arm, thin fingers and a lift
Old Aug 6, 2007 | 11:11 PM
Rick's Avatar
Is this it?
yes that is a good photo showing how not to park your car on a ramp
Old Aug 6, 2007 | 11:32 PM
Brettus's Avatar
Boosted Kiwi
holy sh*t - I didn't notice that . I bet the wheels weren't chocked either .....
Old Aug 7, 2007 | 12:12 AM
true dat
Old Aug 7, 2007 | 07:10 AM
savedsol's Avatar
Carbonormous
His car is an 04. I would hope the oil filter has been off before.
EDIT: One thing to note is that you need a new crush washer for the oil pan drain plug. DO NOT reuse the one that was there. Not to bust your ***** but don't forget to remove the old one either.
Old Aug 7, 2007 | 08:10 PM
woodysjh's Avatar
Judging by the way he parks on the ramp, it would be an assumption that the oil has been changed before on this car.
Replacing the crush washer isn't necessary either.
Old Aug 8, 2007 | 06:12 PM
Crazy Rx-8 Driver's Avatar
XYELLR8
Just dip your finger in the new oil and rub it around the rim of the new oil filter to lubricate it a bit, so it wont seize on next time you attempt to change it.
changing out the spark plugs wasnt so bad. just takes time. I'd say it's a lot easier than changing a standard FWD V6 engine. and a little bit harder then changing a typical honda or any FWD Inline-4.
Old Aug 8, 2007 | 06:33 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yeah...............you should at least take a look at the washer and see if it really needs to be replaced. You don't have to do it every time, but then again......not that expensive.
I would at least start the filter and make sure it will turn.
Drain the oil.
Remove and replace the oil filter, but you should rub a little oil on the new gasket(like has been said) and only put on hand tight! They will tell you to tighten 1/4 turn after gasket makes contact, but I always go a little bit more. Oh yeah...might want to wrap a rag around underneath the filter so any drippage would be caught.
Clean off the drain bolt and washer................inspect the washer.
Clean around the hole in the drain pan. Wipe off is enough.
Re-install drain bolt(with washer!)
Add oil
Take old oil to be reprocessed(Autozone or somewhere else)
Sounds like a no-brainer to most of us, but if you've never done it then..............
And oh yeah..............just to give you more crap! Don't park like that on those ramps! I actually change my oil all the time without lifting, you just have to be ready to lay on the ground a little.
Old Aug 9, 2007 | 12:42 AM
Brettus's Avatar
Boosted Kiwi
I would add this point as I just did my change this morning - remove the dipstick and put your hand through the gap where the dipstick was. That way you can get much better purchase on the filter when undoing by hand.
also : Drive onto a 1" packer (wooden pail or something) - that makes the job a lot easier .
Old Aug 9, 2007 | 09:07 AM
Blacknoir's Avatar
6SPDUFO
Oil is changed! Thanks guys.
Old Aug 13, 2007 | 12:17 AM
Hey you need to get togeather with the 4 years to super charge.
uZu
Dec 30, 2015 12:35 PM
Sifu
Aug 30, 2015 10:51 PM
Obivious
Jul 29, 2015 05:57 PM
dbarber
Jul 25, 2015 01:34 PM
RotaryRider
Jul 20, 2015 07:05 AM
