Gears
Old Oct 7, 2003 | 07:12 PM
P-Rock's Avatar
Gears
I have looked every where and havn't found any info on gears. I was told that it may have a ford ranger rear end. If any one knows what kind of gears or what rear end the rx-8 matchs with it would be a big help.:D
Old Oct 7, 2003 | 08:03 PM
Gord96BRG's Avatar
Re: Gears
It's pretty widely published and discussed that the RX-8 uses a torque sensing limited slip differential manufactured by Tochigi-Fuji corporation of Japan (same as Torsen LSD). I'm pretty sure those aren't used in a Ford Ranger! Diff ratio is 4.44:1 (also unlikely to be found in a Ranger).
Regards,
Gordon
Old Oct 8, 2003 | 06:48 PM
P-Rock's Avatar
Thanks for the info, do you think there will gear replacements in the future as aposed to replaceing the housing?
theblinkof
Oct 4, 2023 05:24 PM
nowakm99
Oct 9, 2015 07:10 AM
Luke.s
Sep 30, 2015 05:57 PM
Zube6115
Sep 30, 2015 12:57 PM
juicemantwon
Sep 26, 2015 12:30 PM
