Burnt Cds Problem ?
Old Aug 3, 2007 | 09:27 AM
maddy420's Avatar
Burnt Cds Problem ?
i have a normal 6 cd changer on my 8. but it doesnt play any of my burnt cds .. it plays sometimes but keeps skipping .. it just depends on my cars mood .. i tried many solutions like burning at low speed?, good quality cd ? etc.
can someone who can play normally tell me how do you do it ?
which software to burn ?
at what speed ?
what kind of cd (cd-r , +r?)
which format ? (cda or wav)
any specific kind of cd ?
Old Aug 3, 2007 | 10:41 PM
maddy420's Avatar
i bought and tried different kind of cds (cd-r, cd+r, cd-rw) etc .. but nothing works
Old Aug 3, 2007 | 11:27 PM
mmats69's Avatar
93.5 octane
i have the regular cd player and have no trouble playing any cd's. Are you closing the cd before you take it to your car and try to play it?
Old Aug 4, 2007 | 12:29 AM
Spinning Sushi's Avatar
I <3 Sushi
Are you sure you're burning audio CDs? You might've burnt it in data.
This happened in my old car, I had a G35, when I burnt CDs with Data Text in it, it wouldn't play. (Like when you play the CD and the display show what song is playing) Try to burn an audio CD without the Data Text.
Old Aug 4, 2007 | 01:03 AM
Jethro Tull's Avatar
Living In The Past
Burn your CD's at the lowest write speed you can. I've had this problem but only with CD's burned at really high speeds, like above 16x. Those burned at 56x rarely run on anything without some songs being unplayable on any CD player.
I now burn at 8x and no longer have any skip or readability problems at all.
Most burning programs will allow you to adjust the write speed.
Old Aug 5, 2007 | 07:34 AM
maddy420's Avatar
i always make an audio cd .. never data .. n i even tried burning at 1x speed .. nothing works now ..
Old Aug 5, 2007 | 07:39 AM
Kane's Avatar
What software are you using?
Have you tried on any other CD players?
Old Aug 5, 2007 | 08:29 AM
firebirdude's Avatar
User and Abuser
Burn slow. Use quality media. Always burn as audio disc vice Data or MP3 disc. (ie 80 Minutes on disc versus 700MB on disc)
I use Nero 7 Ultra Edition. Have yet to have a single read issue in my 8.
Old Aug 5, 2007 | 08:59 AM
DarkBrew's Avatar
Extraordinary Engineering
I've had trouble with maybe 1% of burnt CDs
Use a good (modern) burner and brand name disks.
Old Aug 5, 2007 | 09:05 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Think the biggest thing you need to do is to take some of those burnt discs and try in another player. If you are burning below 8x and using good quality discs that should be more than enough. As someone said, you need to check that you are formatting correctly, using a readable format(no data) and closing the discs properly. If you want more help, you're gonna have to tell us what program you are using and what format you are trying to write. We don't know how experienced you are doing this.
Old Aug 5, 2007 | 09:07 AM
WoodsOfGreenRx8's Avatar
My RX doesnt like to let me skip songs on a burnt CD. If I do that, it just stops playing.
Old Aug 5, 2007 | 09:46 AM
DDJFLW's Avatar
You should only use cd-r media
Old Aug 6, 2007 | 09:28 AM
maddy420's Avatar
i used cd-r s , i used different kinds of softwares , tried everything i could ...
it used to play when i got the car ..but now its hopeless
should i try in wav format ? normally its cda format which comes up as audio cd
may be its just i got a **** player and i ran out of warranty
Old Aug 6, 2007 | 03:33 PM
kanedrz's Avatar
kanedrz
I had no problem with my 6-disc player. I use CD-R Memorex and Nero start smart essential. I would say try to use a cd cleaner.
Old Aug 6, 2007 | 03:39 PM
laythor's Avatar
I zoom therefore I am.
Line in adapter and all your worries are gone.
Old Aug 6, 2007 | 08:59 PM
R888's Avatar
WedsSport Member
If the skippy problem still exists, talk to your dealer. They will change it for you for free if you are still in warranty.
I did mine couple months ago, is fine now.
Old Aug 6, 2007 | 11:40 PM
yellowRX's Avatar
Piston? What's a piston
I have the same problem sometimes, I never tried a lower speed because when I keep popin in the disc it just plays sometimes. Usually it only happens when I put the burn disc on the first time, after that it plays all the time. I always thought it was strange myself.
puff's Avatar
the rx-8 cd player is very picky on cd-rs and some commercial cd's. it has problems playing back cd-rs burnt from my both my macs.
Old Aug 7, 2007 | 11:18 AM
maddy420's Avatar
which brand of cds should i try ? and what kind ? cd-r or cd+r or anything else ? wav or cda format?
Old Aug 7, 2007 | 11:22 AM
Rems31's Avatar
maybe your CD's are just too scratched for the player to read it...
Old Aug 7, 2007 | 11:54 AM
very strange.
I've used Memorex CD's burned with Nero and they've always worked; both with my single disc and now with the single disc mp3 unit.
do the discs play in anything else other then your computer?
theblinkof
Oct 4, 2023 05:24 PM
Zube6115
Sep 30, 2015 12:57 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
