low pitched whistle when accelerating
Old Oct 6, 2003 | 03:40 PM
sup3rbad's Avatar
Numbah 1 in da hood... G
does anyone hear the low pitched whistle when accelerating? i hear it usually when lightly press the gas pedal. i was wondering if that was normal.
Old Oct 6, 2003 | 06:07 PM
mikeb's Avatar
100% Italian
that is not normal or atleast I havent heard it
Old Oct 6, 2003 | 06:13 PM
Gyro's Avatar
Rotary Abuser
I would check to make sure a vacuum line didnt detach.
Has the car always done this or is it a new noise?
Did you have a an oil change lately ( there are a few vacuum lines in the area of the filter)?
- If you just got your car, and are unfamiliar with rotaries, it might just be that lovely whine the rotors make. However I'll give you the benefit that you know its not that
Old Oct 6, 2003 | 06:50 PM
sup3rbad's Avatar
hmm maybe its the rotors spinning. but i'll check if it keeps up. i hear usually when the engine isn't revving so hard and usually during 3rd and 6th gear
Old Oct 7, 2003 | 06:50 PM
sohcpunk's Avatar
I think thats the sound of the whirling rotary engine. I can hear mine when im driving really slow around a parking lot but when your cruising at high speeds, the noise is gone because there are other road noises around.
Old Oct 7, 2003 | 08:43 PM
blizz81's Avatar
That might just be first gear whine due to the synchros, which is fairly common for MTs as far as I know. Was what I was going to suggest, but the poster said 3rd and 6th gears.
I have a whistle-like noise that can be noticable from the Bose amps (I believe) in my car when my stereo is on. If I cut the power to the deck, it stops. One more thing to try I suppose, if the radio isn't already off.
Old Oct 7, 2003 | 08:52 PM
sohcpunk's Avatar
I have the AT and come to think of it, it only has that whining sound in first gear.
Old Oct 10, 2003 | 11:10 AM
Bolder8's Avatar
Mine has 100 miles on it in 4 days and I have the same noise. The whir of the Rotary is distinct but this sounds different and is only noticeable at very slow speeds. I wondered if it was "normal" as well. The radio is off when I hear it.
Old Oct 10, 2003 | 12:02 PM
Magnesium's Avatar
Lurking troll
After reading this post a couple of days ago, it made me listen carefully once or twice while depleting my gas level rapidly
I did hear a whistle type sound, I think it is the gulping for air that is causing it.
Old Oct 11, 2003 | 03:03 AM
WTF no turbo's Avatar
Im getting same noise during hard reving in every gear.I will try to pin down the noise tommorrow but it does sound like a little whistle under the hood.
Old Oct 11, 2003 | 08:58 AM
jdl's Avatar
jdl
just jd.
Re: low pitched whistle when accelerating
This is an accurate description for me, too. It's pretty distinctive, too. Now over 25K, started noticing it sometime after 12K. It definitely wasn't there early on.
sup3rbad, any chance you noticed the sound only after an oil change?
Edit: "Now over 2.5K , started noticing it sometime after 1.2K ." Sorry! I didn't finish my coffee before that message!
Old Oct 11, 2003 | 09:32 AM
JoeRX8ter's Avatar
You have 25K on your Car already? WOW, hows she doin?
Old Oct 11, 2003 | 10:02 AM
Magnesium's Avatar
Lurking troll
That is some serious driving.
I will have about 9K on my car when I complete my road trip in a few weeks. I will post if I have any problems.
Old Oct 11, 2003 | 11:27 AM
jdl's Avatar
jdl
just jd.
Rats! typo: I edited my post to say I meant 2.5K. Sorry to cause all the excitement
Old Oct 11, 2003 | 02:56 PM
sup3rbad's Avatar
nope, no oil change yet. i'm on 1.5 k, when should i get an oil change?
Old Oct 11, 2003 | 06:50 PM
mikeb's Avatar
100% Italian
maunal says 5k
did mine at 2900
cliffkemp
Dec 24, 2024 10:48 AM
Michael Bryant
Oct 12, 2015 03:07 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
