Tire pressures
Old Jul 12, 2007 | 12:58 PM
Mazdagirl's Avatar
Tire pressures
Hi Guys,
I just purchased some Falken Azenis RT 615... They have made a HUGE difference for me! I'm now beating the 350Z guys in my class!
Anyways... I have been running PSI 30 front 28 in the rear..
I have been doing some reading and I think it should be higher?
Any thoughts?
Thanks =)
Beth
Old Jul 13, 2007 | 10:07 AM
yiksing's Avatar
the giant tastetickles
Isn't recommended pressure in the manual says 32 psi? so probably more at autox
Old Jul 13, 2007 | 12:06 PM
alnielsen's Avatar
Maybe slightly more pressure 32-35 for those tires. Are you autocrossing? Have you been checking for how much tire roll your getting?
Old Jul 13, 2007 | 01:18 PM
Mazdagirl's Avatar
Yes I AutoX... I have only raced on them 2 times and was running 30 front and 28 in the back...
Old Jul 13, 2007 | 01:21 PM
alerx-8's's Avatar
im also interested on what tire pressure to run. not sur if i just keep it up the recommended level or bump it up a few.
Old Jul 13, 2007 | 08:19 PM
NoRotorNoMotor's Avatar
Mazda Only. 10+yrs
Reccomended pressure in my manual (2005 GT) is 35psi all the way around.
I run at 37 evry day .... 38 for AX ... but I may try it lower next event.
Old Jul 13, 2007 | 08:21 PM
Cody Red's Avatar
always filling [the c]up
32 all around just like in the manual is fine.
i'm keeping up with the 'faster' cars with these settings.
Old Jul 13, 2007 | 11:17 PM
Holy Transformer!
Old Jul 16, 2007 | 05:22 PM
Mazdagirl's Avatar
Thanks for the input on pressures, I raised them to 32 front and 30 rear and came in first out of 4....
Old Jul 16, 2007 | 05:25 PM
staticlag's Avatar
The Professor
for autox with the RT 615s i have found 34-35 psi all around to be just right. These are hot pressures, so check them before each run to make sure that your heading out there with those pressures.
Old Jul 17, 2007 | 08:36 AM
CosmosMpower's Avatar
1935 lbs. FTW!
I liked 32/30 or 34/32 on my 255/40/17 RT615's.
Old Jul 17, 2007 | 10:58 AM
Derex'8's Avatar
ReDuX
31/29 on 245/40/18 SPTs
Old Jul 18, 2007 | 01:21 PM
timaf's Avatar
it is what it is
autocrossing 615's
The manual is not going to help you with autocrossing or 615's. Pick a starting point, chalk the side walls and see how much roll you have.
Old Jul 19, 2007 | 04:00 PM
Derex'8's Avatar
ReDuX
Originally Posted by Mazdagirl
Hi Guys,
By how much were they beating you before 615s and by how much are you beating them now?
Old Jul 19, 2007 | 06:39 PM
Mazdagirl's Avatar
Times usually looked like this:
Them 42.202
Me 42.213
Now I'm
Me 40.661
Them 41.518 and 41.601
I cant believe the difference......... Its either the tires or I'm getting better!!!!!! Or both!!!
Old Aug 4, 2007 | 03:45 PM
Both
Old Aug 4, 2007 | 05:21 PM
Silver_Surfer's Avatar
I4NI
Why are most of you(Auto-X) guys running less pressure in the rear?
Old Aug 8, 2007 | 12:01 AM
traction.
Old Aug 8, 2007 | 12:06 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Actually, you are gettin' worse, but the new tires are doing all they can to keep up. Balances out for the better in the end.
BTW, my tires get down right sloppy at 32. I keep them around 38.
Old Aug 9, 2007 | 08:36 PM
I4NI
Originally Posted by Razz1
traction.
Yeah, Duh!
Just over thinking......
Old Dec 6, 2010 | 06:51 PM
wrightcomputing's Avatar
Made in England
When I autocross I Chalk the tires in 3 places then set the tire pressure about 40 all round and drop until I am using all the tire. Typically 40 up front and 39 at the back. When you get better you will use more of the tire because you corner quicker so you need to increase the pressure. Chalk line should be rubbed off where the tread is but not rub on the side wall. Some tires have a little arrow to show you where the best line is. Best thing to do is trail and error if you change is by about + or - 2 psi you should really feel the difference in the cars handling.
cliffkemp
Dec 24, 2024 10:48 AM
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
