Very low air fuel ratio, low 11s
Old Jun 29, 2007 | 04:47 PM
mazdaexe's Avatar
Hi, I just got my Hymee Scanalyzer and was able to do some WOT runs.
The Air/fuel ratio dropped to a low 11s at WOT. I know our cars run rich, but 11s seems awefully low (rich).
Is this normal? Or is the ECU doing this because of some reason? E.g. Cat failing?
I know this topic has been discussed across the board, but I havent seen anybody with readings lower than 12..
Thanx
Old Jun 29, 2007 | 05:05 PM
They will go down to 10.5 ish or slightly below.
Ever wonder why we are down on power
Old Jun 29, 2007 | 05:22 PM
mysql101's Avatar
yeah - you should be able to pick up 10-15 hp just by leaning it out.
that's why we all had canzoomer ecu piggybacks a few years ago
Old Jun 29, 2007 | 10:45 PM
and why i have the RB flash now
Old Jul 28, 2007 | 10:08 PM
WoodsOfGreenRx8's Avatar
Zoom.
So the RB flash leans it out? Did you get the racing flash or just the street flash & where can I get this canzoomer, if I still can get it?
Old Jul 29, 2007 | 11:40 AM
forget canzoomer- get the rb flash or wait a little longer for the Cobb AccessPort RX-8 version.
i have the "street" flash
Old Jul 29, 2007 | 11:43 AM
StealthTL's Avatar
Why did you go "street", Zoom?
S
Old Jul 29, 2007 | 12:11 PM
Sweet, thanks Zoom!
Old Jul 30, 2007 | 06:32 PM
RoXanneBlack8's Avatar
stop flooding ur engines
anybodys flash remove the limiter?!
i dont trust cobb.....leave them the subarus, when it comes to MOPs ill leave my pcm for RB
Old Jul 30, 2007 | 06:50 PM
Jax_RX8's Avatar
Got Another Rotary
RB Flash moves the limiter from 9000 to 9300.
What other "flashes" are there right now? I know of a few separate management systems, but no other flashes.
BTW - anything above 10k rpm is bad news for for the stock and most aftermarket flywheels for the 8 - and I wouldn't want one of those failing on me.
Old Jul 30, 2007 | 09:58 PM
restiller's Avatar
sofa king
is it safe to assume that the RB flash will increase mpg WHEN DRIVING CONSERVATIVELY since it leans out the mixture?
Old Jul 31, 2007 | 11:43 AM
Jax_RX8's Avatar
Got Another Rotary
RB states most of the changes are above 5000 rpm with the most impact at 7000+, so low rpm normal driving will have little effect on performance and mileage.
RicerX1
Jan 11, 2016 05:59 PM
uZu
Dec 30, 2015 12:35 PM
harithac
Aug 17, 2015 09:14 AM
harithac
Jul 31, 2015 09:57 PM
AussieGray
Jul 16, 2015 03:58 AM
