So dumb - Accidentally left Park Brake on :(
Old Jun 24, 2007 | 01:24 PM
PatInTheHat's Avatar
So I accidentally drove about 1/2 mile at very low speeds with my park break on. I then started accelerating and hit around 60mph before realizing something was wrong and then noticing the park break still engaged.
How bad is this and what damage might I have caused? Anything I should do or check?
Old Jun 24, 2007 | 01:28 PM
tiggerlee's Avatar
May Cause Anal Leakage
Was the E-brake light not on?
Old Jun 24, 2007 | 02:07 PM
DarkBrew's Avatar
Extraordinary Engineering
You probably didn't hurt anything but you really shouldn't do it again! You should be scanning you instruments as you drive... It's pretty hard to miss the brake light!!
Old Jun 24, 2007 | 04:20 PM
NotAPreppie's Avatar
What am I doing here?
Wait, you didn't notice the additional drag on the car?
Old Jun 24, 2007 | 07:10 PM
If it didn't smell real bad like burning brakes...you will be OK. If you cooked it really well..you might want to lube the caliper slides on the rear calipers and change the brake fluid..
Old Jun 25, 2007 | 10:40 AM
tiggerlee: brake light was on.
DarkBrew: Yeah I know Can't believe I didn't see it right away.
NotAPreppie: I was going very slow getting of of a gravel road, I didn't notice the additional drag until I started accelerating which was when i noticed the park brake.
dannobre: I didn't notice much of any smell.
Old Jun 25, 2007 | 01:29 PM
It doesn't sound like you had the brake on very "hard" (for lack of a better term). I'd guess you are okay, but you might want to do some preventative maintenance (lube the caliper slides, check the rotors for cracking, etc). This is one of those components that you just don't want to leave to chance.
Old Jun 25, 2007 | 04:23 PM
altspace's Avatar
Eccentric Shafting
^exactly. My car won't budge with the e-brake on.
Old Jun 25, 2007 | 04:41 PM
RotorManiac's Avatar
Absolute Rotary Madness
Originally Posted by PatInTheHat
....I was going very slow getting of of a gravel road, I didn't notice the additional drag until I started accelerating which was when i noticed the park brake....
no worries then, I've seen a guy trying to drift his 8 with the e-brake on.... well, he managed to drift and when he stopped he found out what was keeping him back... he also managed to light up the rear brake pads too lol
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
RXFEVER
Aug 29, 2018 10:14 AM
stickmantijuana
Sep 4, 2015 10:31 PM
