Smoother clutch disc
Old Jun 20, 2007 | 06:10 AM
titaniumgr3y's Avatar
JDM-8
Question Smoother clutch disc
Guys, my 8 has 30k miles on it, japanese version, 6-speed, its 2003.
I need to change my clutch disc as it kicks a little on the shifting from 1st to 2nd etc.
i believe it will be cheaper to buy an aftermarket clutch kit and replace stock one with it, but.,,,,,,,,,,,
do you have anything in mind of a smoother&faster clutch kit?
will i need a new aftermarket flywheel as well?
Old Jun 21, 2007 | 04:42 PM
whenson417's Avatar
Clutchmaster Stage 3 is what I have and I couldn't be happier. The pedal is actually lighter feeling than my stock clutch was. One thing I have noticed lately is that the pedal is easier to push in the higher the rev's are.
Old Jun 22, 2007 | 01:54 AM
JDM-8
how about shifting ? does it kicks you ? faster response?
Old Jun 22, 2007 | 05:59 AM
JDM-8
actually i need to replace stock to gain the following:
lighter pedal or close to same but not heavier
smoother shifting
higher performance
Any clutch kit complies ? :P
Old Jun 22, 2007 | 03:12 PM
whenson417's Avatar
My shifting actually got smoother. But keep in mind that I had a new clutch and lightweight flywheel installed while my engine was being replaced under warranty. So I am not sure if the shifting is better do to something they did while swapping the engine but it sure is better than it was before. Clutchmasters uses a stage one pressure plate for their stage 3. I am still not use to the clutch yet so I am sure that shifting will be faster once I figure it out. It seems to get lighter and engage sooner as the rpms get higher.
Old Jun 22, 2007 | 06:13 PM
Fanman's Avatar
Yeah on my Centerforce unit. It is good up to 400 ft. lbs of tq and the engagement is smoother & lighter. Many people that have driven my car have commeted how the clutch is surprisingly light compared to stock let alone an aftermarket unit.
Old Jun 24, 2007 | 03:05 AM
JDM-8
omg man, i need to replace my stock one soon.
I really have a problem when there is traffic and i go from first gear to neutral and then back to first. it kills my leg :P
Old Jul 3, 2007 | 10:33 AM
Rhythmic's Avatar
Laid back in the pocket
Is there any noise/chatter with the Centerforce stage 3? How many miles on it?
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Kim Jong Illest
Sep 4, 2015 04:27 PM
