I need wheel answers
Old Sep 28, 2003 | 05:48 PM
jaybraveheart's Avatar
I want to puchase whels and want a 19 10 in the rear and 19 8 in the front. Anybody who has answers will be great.
Will those sizes fit The RX8....
Old Sep 28, 2003 | 07:52 PM
Redshift's Avatar
Spinning Dorito Junkie
It would help if you asked a question.
Old Sep 28, 2003 | 08:28 PM
eccles's Avatar
Prodigal Wankler
42 :D
Old Sep 28, 2003 | 08:35 PM
Redshift's Avatar
Originally posted by eccles
42 :D
Bwahahaha... literally LOL. Nice one.
Old Sep 29, 2003 | 12:07 AM
mikeb's Avatar
100% Italian
he asked if they fit
19x8 in the front would fit
but 19x10 in rear I'm not sure about
Old Oct 20, 2003 | 04:46 PM
SleepR1's Avatar
Re: I need wheel answers
I don't get it? Why 19s, and why such a huge stagger between fr/rr? 19s on Rx8 don't buy any performance. If anything, you're degrading performance and ride comfort; and you if you don't pay attention to overall tire diameter when upsizing (which apparently many of you don't), you end up raising the ride height of your Rx8 by 0.5 inches. As for the stagger, the Rx8 already has plenty of understeer dialed in for the average (read untrained in performance driving) driver, so a stagger with the front end being 2 inches narrower than the rear, will dial in so much understeer, you might as well go back to driving your FWD Honda Civic. The Rx8 only makes 238 flywheel hp. Consider that the 8 weighs 3000+ lbs so weight-to-hp ratio is not that great, compared with a stock FD3S. My point is, the 8 will not have the power to oversteer the car with your right foot, unless you purposefully induce oversteer, by braking into a turn very late, and applying the throttle to rotate the rear end. With 10s in back you'll never be able to rotate the car into a turn properly. Ok sermon over...
Old Oct 20, 2003 | 06:05 PM
PUR NRG's Avatar
Re: Re: I need wheel answers
Funny you should say that. I've been autocrossing the car and I find even with moderate trail braking or fast left/right transitions the rear end breaks loose way too easily. Seems like fatter rear tires and/or larger front sway bar is the way to prevent this.
Then again my driving style may change enough so it isn't a problem any more. [shrug]
________
ZX14 VS HAYABUSA
Old Oct 20, 2003 | 07:29 PM
ACOSTARACING's Avatar
I have 19x10 in the rear. and 19x8.5 in the front. and they fit with no problem. I'm using 285/30R19.
Evan Gray
Nov 24, 2015 01:00 AM
snowrydr01
Nov 23, 2015 09:40 AM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
