cai and water injestion
Old May 27, 2007 | 05:50 PM
RX-8Newb's Avatar
have never owned a cai intake before b/c all of my other cars were turbo and did not need it. So i saw a vid on youtube of an 8 with the aem cai and it looked like it was in between the bumper and radiator. When it rains do you have to worry about the filter element getting wet or is it high enough up that it is not an issue? I searched to no avail. Thank you.
Old May 27, 2007 | 06:13 PM
CKay's Avatar
Hey Bro, just to let you kno, all turbo cars have a CAI system. Also have you looked at the Racing Beat w Duct CAI system, the filter is in the engine bay and the duct has holes to help drain the water so you don't have flooding problems.
Old May 27, 2007 | 06:29 PM
Brettus's Avatar
Boosted Kiwi
been through some pretty heavy rain with my RB duct (up to 200 km/hr on the track as well ) with no problems .
Old May 27, 2007 | 10:39 PM
Search Buddy, Please Search !!!!!!!!!!!!!!!
Old May 28, 2007 | 01:14 AM
RX-8Newb's Avatar
i was unaware of the cai system on my talon seeing how the filter was damn near attached to the turbo, if you are about the intercooler, that is a charged air cooler not a cai, i tried a search first, if everyone just wants you to search and not post then this would be an archive and not a forum.
Old May 28, 2007 | 01:26 AM
rg200amp's Avatar
gr8ness
yea most trubos have a short ram intake, not cold air. the filter is in the engine compartment.
the aem cold air is ok in the rain, but watch out for puddels they can get you.
also cai and sri dont do squat for the 8 except make noise. not theres anything wrong with that. thats why i probly wil get one. you might get 1-2 HP pending weather.
Old May 28, 2007 | 02:55 AM
LabDad's Avatar
Doggie Style :)
So CKay, have you reasearched every turbo car in order to make a statement like this?
Old May 28, 2007 | 03:07 AM
BigRed's Avatar
w8nkel
i think he just meant an intake by itself. oh well
Old May 28, 2007 | 03:58 AM
Brettus's Avatar
Boosted Kiwi
think you need to read up on what a ram air intake is ....
Old May 28, 2007 | 05:28 AM
BoosTED's Avatar
Don't forget to mention that the 8 comes with a Cold air intake - it takes air from outside of the engine bay.
Anything on water injection?
Old May 28, 2007 | 08:08 AM
RX-8Newb's Avatar
if the gains are so minimal then why do all the companies say it gives almost 10whp. Is that all hype? I think i will save some $ and just get the new typhoon then if they dont make that much of a diff anyway
Old May 28, 2007 | 08:24 AM
PerformRX-8's Avatar
ROTARY-A-HOLIC
I have the AEM CAI, the intake has to be fully submerged for there to be any kind of damage to the engine.... actually in the rain it just gets soaked a little and it sounds really cool...but if you do drive into a puddle that submerges the intake, its your own damn fault that your engine is destroyed cause that just means your stupid! if you think your intake will get submerged then don't drive in it...
Old May 28, 2007 | 08:33 AM
mysql101's Avatar
you can buy water proof "socks" that fit over an intake filter that will prevent it from getting wet and also help in blocking dust... I saw some for sale on cardomain the other day.
Old Jun 3, 2007 | 10:36 AM
04_Mica Mazda's Avatar
Run and Tell That...
x2... i have the aem intake also and i have driven in the rain many many times and have had no problems with water injestion, but i do avoid the really big puddles. i also have a cold air on my 95 V6 MX-6 and the filter sits about 3 inches above the ground and i have never had a water problem in nearly 5 years!
Old Jun 3, 2007 | 10:41 AM
PerformRX-8... did u take off your front bumper when u installed the AEM?? i tried to install without removing the bumper but failed miserably
Old Jun 3, 2007 | 11:42 AM
chickenwafer's Avatar
Nope
yes, you MUST take off the bumper. It's pretty easy to why not?
Old Jun 3, 2007 | 12:35 PM
i did end up taking off the bumper, but i tried to be a lazy *** and not take off the bumper, but i learned my lesson
Old Jun 3, 2007 | 10:17 PM
jdzoom8's Avatar
I have the Mazdaspeed CAI and about 3 times I have had issues with "water" getting up in my intake. I never have submerged my filter, I believe it has come more from condensation forming inside my intake and on my MAF?. Each time my car has bogged down severely and had a Check Engine light come on. I pulled my Mass Air Flow Sensor and found it to have water on it each time. I simply took it off and blew the water out and let it dry out for a few minutes, reset my CEL lights, and away I went. I always keep a philips head in my glove compartment to remove the MAF in the event this happens again. This happen to anyone else?
Old Jun 3, 2007 | 10:43 PM
what was the cel #. i have been running the revi and duct for i guess 2 years no problem...
if some one has really injested water into the engine natural selection should take care of the problem.. as you have driven into at least 2 ft. of standing, or moving water..
Old Jun 3, 2007 | 11:48 PM
c0ldf1ame's Avatar
a little water will evaporate before it gets into the combustion chamber, also a little will help u cool the intake charge. Refering to cars that have water injection kits.
U will hydrolock only if you run into a HUGE puddle, other than that it should be fine. If you are really concerned, they have valve systems for aem cais that prevent water injection, but it kind of defeats the purpose of a cold air intake anyways.
Old Jun 4, 2007 | 12:06 AM
rotarygod's Avatar
I have personally fixed an RX-7 that ingested water in a flood. Took everything apart and poured water out of the intake and exhaust and the intercooler. Drained the engine block. Replaced all fluids and pulled the engine down the street. It eventually started again and came back up to full power! This engine had flood water in it! Rotaries are neat devices.
Old Jun 4, 2007 | 07:16 AM
RX-8Newb's Avatar
i was more concerned with problems from the filter element becoming wet. I really dont want to take the front bumper off too, i am lazy. I have a tendency to take things off cars and not remember how to get them back on lol
Old Jun 4, 2007 | 07:38 AM
lurch519's Avatar
www.evoperform.com
Originally Posted by c0ldf1ame
a little water will evaporate before it gets into the combustion chamber, .....
um, i dont think so.
......... If you are really concerned, they have valve systems for aem cais that prevent water injection, but it kind of defeats the purpose of a cold air intake anyways.
uh, no again. they do have whats called the air bypass valve, for most of their intake line, but they do not have one that will fit their intake for the rx-8
Old Jun 4, 2007 | 08:47 AM
water ingestion is not the same as water injection
Old Jun 4, 2007 | 03:11 PM
my AEM came with detailed instructions and the bumper removal and re-installation were quite easy. i wasted more time trying to get off the stock "pipes" off than taking off the bumper, removing the old, installing the new, and putting the bumper back on
