What wheel dimensions to avoid tire rolling?
Old May 17, 2007 | 05:48 AM
rb67's Avatar
What wheel dimensions to avoid fender rolling/tire rubbing?
Let me first say that I'm a newbie when it comes to aftermarket auto parts. This is the first care that I liked enough to want to improve it.
I'm considering getting new 18" wheels on a stock 2004 rx8. I've read around that some members needed to do some fender rolling to avoid rubbing. What type of tire dimensions should I look for in order to avoid having to roll the fenders?
Width? (7.5, 8, 8.5"....)
Offset? (38, 40, 45mm ... ) <--- This I don't really understand much.
I hope this isn't too silly of a question.
steve
Old May 17, 2007 | 06:18 AM
Imidazole's Avatar
I think tire Rolling and Rubbing are two different things.
Old May 17, 2007 | 09:39 AM
8is>enuff's Avatar
Bland
For starters - http://www.1010tires.com/tech.asp
You can get up to 9.5 without any rubbing if the offsets are correct. Check the Enkei RPF1 thread for the correct offset.
Old May 17, 2007 | 11:29 AM
BigRed's Avatar
w8nkel
^^correct. from what i heard, tires are supposed to roll
Old May 17, 2007 | 11:40 AM
TownDrunk's Avatar
I am a meat popcicle
You can go a bit wider than that even (well in the rear). I have 18x10 +50 in the rear, no rubbing, therefore no rolling required.
Old May 17, 2007 | 12:39 PM
rb67's Avatar
oops, I meant fender rolling and tire rubbing.
Thanks for all the great info.
Old May 17, 2007 | 02:38 PM
8is>enuff's Avatar
Bland
I meant non-staggered, but you are correct (obviously, as you have them on your car).
Old May 17, 2007 | 02:46 PM
TownDrunk's Avatar
Werd
gwailo
May 14, 2024 06:57 AM
Octomus
Sep 3, 2015 11:40 AM
20b-3rotor
Sep 2, 2015 08:54 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
