Could more active fan help reduce post-drive cabin heat?
Old Sep 26, 2003 | 06:37 AM
ezradg's Avatar
Conclusion from a number of threads discussing post shutdown engine fan operation seems to be that the engine fan will stay on for about 10 minutes if the radiator temperature is sufficiently hot.
My question is whether or not the fan should be coming on more often to help cool the engine compartment. I ask this not from a technical perspective (I feel comfortable that the fan is set so that the engine will cool appropriately), but more from a view towards increased comfort/driveability. Like a number of others I have noticed the heat trapped inside the cabin after returning to my car which was parked (in the shade) after a 30 minute plus drive. (This is pretty uncomfortable, particularly on hot days when I am wearing a suit and tie!)
Could having the fan trip on at a lower temperature (and thus more often) help cool the engine compartment and thus avoid this problem?
Old Sep 26, 2003 | 02:21 PM
mikeb's Avatar
100% Italian
I wouldnt mess with it
Old Oct 2, 2003 | 03:46 AM
ezradg's Avatar
Not sure what you mean by that mikeb. I do not plan on changing anything myself. Just wondering whether or not this would be an easy adjustment for Mazda to make that would address a reasonably simple issue. Many cars have the fan come on after shutdown on a regular basis.
Old Oct 2, 2003 | 07:57 AM
syntrix's Avatar
I like cheese!
You'd probably get cooler results with a cooler thermostat.
But that could cause run issues in certain climates.
Old Oct 2, 2003 | 05:01 PM
mikeb's Avatar
100% Italian
sorry
by all means explore
I thought you were going to mess with it
cliffkemp
Dec 24, 2024 10:48 AM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
XianUnix
Sep 29, 2015 03:48 PM
