Coils life span?
Old May 15, 2007 | 02:46 AM
titaniumgr3y's Avatar
JDM-8
Question Coils life span?
Guys,
what is the life span for Rx8 coils ?
do we have any info?
Old May 15, 2007 | 06:40 AM
eforer's Avatar
Originally Posted by titaniumgr3y
Guys,
I can tell you first hand that the original coils released with the car in the 04 model don't last long. I replaced mine with the updated ones at 8k. So far so good with the updated coils though.
Old May 15, 2007 | 06:49 AM
O'Renesis's Avatar
Technically the ignition coils should last the lifetime of the car. Coils have no moving parts and consequently have nothing to wear out. In the hostile environment of the engine bay properly designed coils should have no problems. Apparently the coils used on the RX-8 are prone to failure due, I believe, to inferior quality build. It appears that the insulation breaks down causing the coils to short/ground on the high tension side. There is no way of knowing if or when a coil will fail. Mazda say they have a new and better coil, but I personally cannot verify this and I believe it is early days for any of the new coils to start failing. Time will tell.
Old May 15, 2007 | 07:04 AM
expo1's Avatar
He's as bad as Can
My 8 was built 5/2003 and I have 92,000 miles on the original coils.
Old May 15, 2007 | 07:41 AM
They are cheap...and appear to fail often before 50K miles.....I just bought a set shipped for $109US........about the same price as new plugs
Old May 15, 2007 | 08:07 AM
brillo's Avatar
Go Texas Longhorns!
I'm going to replace mine every 50K, for $100, why the hell not.
Old May 15, 2007 | 08:10 AM
peterlemonjello's Avatar
Mine failed at 42k miles but I'd bet they were degraded way before then. I noticed a big difference with the new coils. My 8 is an 06/03 build date.
Old May 15, 2007 | 11:38 AM
chickenwafer's Avatar
Nope
I have 41K miles and still on original coils. At 50k I'll replace them. Only $100 like others said- they're cheap
Old May 15, 2007 | 12:26 PM
eforer's Avatar
mine failed at 8k (or around there) as I mentioned above. The car sat for almost a year before I bought it. Although that should have no impact on it. I bought it with the 8k miles on it and the coils were bad when I got it. Dealer replaced them, huge improvement.
Old May 15, 2007 | 02:42 PM
JDM-8
nice.. i got the general idea..
Old May 15, 2007 | 10:38 PM
it depends on the condition that you're running your coils @
Old May 15, 2007 | 10:43 PM
70k miles on them. still no issues.
Old May 16, 2007 | 06:32 AM
JDM-8
very nice...
Old May 16, 2007 | 02:40 PM
whenson417's Avatar
Mine new and improved coils are showing the little white spots at about 15k. I suppected them to be bad again because my car died while at a red light last week. I took it in and am currently waiting on my new engine to arrive. Guess it wasn't the coils that caused the engine failure.
Old May 16, 2007 | 03:15 PM
Astral's Avatar
Purveyor of fine bass
Mazda service manual/TSBs (forget exactly which) say that the white spots on the coils are not indicative of coil performance (i.e. you can have a perfectly fine coil with white spots).
Old May 16, 2007 | 06:24 PM
MazdaManiac's Avatar
I've been through 3 or 4 sets over the last 52k miles.
However, only 3 or 4 of them actually failed completely on their own and I burned 4 of them by just being bone-headed (I had my ignition control jumpered for 12v instead of 5v - they lasted exactly zero seconds; at least they were already old).
So, I've had half of my coils become marginal and the other half failed, more or less.
Old May 17, 2007 | 01:54 AM
eforer's Avatar
I thought this https://www.rx8club.com/showthread.p...t=testing+coil blast from the past was relevant to the converstion.
Old May 17, 2007 | 02:01 AM
"Blast from the past"? That is a current thread.
Old May 17, 2007 | 02:58 AM
eforer's Avatar
well, blast from the recent past. Either way, its good reading. Its good to know that even if a coil sneaks by the ol multimeter, it still may be underperforming.
Old May 17, 2007 | 03:06 PM
Marx8nka's Avatar
or failing the multimeter but the car still loves them
Old May 17, 2007 | 03:14 PM
^^ True, though that is pretty rare. Furthermore, if you really press those coils (hot day, drag racing, etc.) they will probably give up on you at a rather inopportune moment.
Most of the time when it seems like the car "loves" those coils, its because they are the trailing which won't be felt by the driver until they actually do fail and kill the idle quality.
Old May 20, 2007 | 08:29 AM
JDM-8
its been a week now that my car has a problem with coils a & c and i havent noticed any loss of power or difference.
Will it take longer to make a difference?
Old May 20, 2007 | 01:01 PM
There was a study that a typical new born human *should* have 250 years of life.
but .... who the fuxk actually have 250 yrs of lfe? cuz it depends on TONS of factors.
so just buy new coils. replace them, be happy, just like me.
Your CEL code wasnt even the valid code. make sure u got the right one dude.
Old May 21, 2007 | 03:36 AM
JDM-8
thanks but, two diagnostic tools would lie ? or my car went crazy ? :P
now ok, i have the burnt coils symptoms and both DT are saying about the coils/coils circuit, i am convinced that i have to replace them.
Old May 21, 2007 | 06:03 AM
dude, but the thing is that the codes that you posted werent valid. at least according to the service manual.
thats why u should've double check b4 u got ur coils.
