How do i put an Amp on my RX8??
Old Apr 29, 2007 | 07:34 PM
willrotary's Avatar
Rotary Dominican Republic
Question How do i put an Amp on my RX8??
Hi I have a 1000 watts mono class D amp i want to connect it just for bass, i did already the Aux input welded inside the head unit(works nice with my MP3 player). ill leave the factory system intact for mid and highs, but i want to know wich cables are the Mute outputs from the radio to the factory ampso i can get the inputs to the new amp. I have already the rest done, please any help on this one can any one tell me the color of the cables on the trunk, i know its the plug with many wires..., Thanks
Old May 1, 2007 | 09:26 PM
RxJaye's Avatar
You can use a high to low convertor and splice into the rear speaker wires after the amp (if Bose). Thats what i did, I have 2 10s that sound great with the bose system.
Old May 2, 2007 | 09:39 AM
willrotary's Avatar
Amp Installation
Thanks man, i was thinking to do that but, does it sound good?? i remember back in the days i did it with a honda accord and sounded noisy, well ill try anyway thanks a lot.
Old May 2, 2007 | 07:23 PM
RxJaye's Avatar
Mine sounds great, First time ive used a factory head unit in a system, but Im impressed.
Old May 4, 2007 | 01:25 PM
imrtommy's Avatar
Need Rotary Engine!!!
What you say works but is only part true. Sound depends on amp. And converter should be pretty good. I used a weak amp and cheap converter and after I turned ignition off it made a continuos bumping. I switched to a better converter and it stopped the problem, but when I upgraded to a jl 1000.1 amp it had that problem again. I had to buy audio line outputs from pac-audio.com to fix the problem. Well I didn't have to but it sounded way better than what it was which I thought was pretty damn good already. =)
Old May 14, 2007 | 04:32 PM
RxJaye's Avatar
Do you know the part number from pac-audio?
rotarywanker
Dec 8, 2022 05:56 PM
delicious_dallan
Jan 17, 2020 09:17 AM
ei8ht
Aug 21, 2017 09:08 AM
Kangarhew
Jul 18, 2015 08:27 PM
