Spark Plugs and Anti-Seize
Old Apr 21, 2007 | 02:16 PM
staticlag's Avatar
The Professor
Is it okay to use anti-seize with sparkplugs?
Or, is the metallic goodness going to work its way into my engine?
Old Apr 21, 2007 | 02:19 PM
Wilson's Avatar
Peeping over the fence
Always use an anti-seize compound on your plugs. It doesn't take a whole lot. Just enough to coat the threads. Wipe off any excess before insertion.
Old Apr 21, 2007 | 02:53 PM
Cam's Avatar
Cam
this space for rent
I was told by a Master tech not to use anti seize on NGK plugs.
Old Apr 21, 2007 | 03:04 PM
Easy_E1's Avatar
iI was working on Mazdas before that master tech was born and I say use anti-seize.
Nothing like getting a sparkplug stuck in a rotor housing.
Old Apr 21, 2007 | 03:23 PM
Use it...it won't hurt anything......you don't need to goop it on though. A little bit goes a long way. Doesn't hurt to put it on a lot of other bolts that you remove either...makes life simpler down the road
Old Apr 21, 2007 | 04:24 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
+1
Old Apr 21, 2007 | 05:04 PM
always have, always will
Old Apr 21, 2007 | 06:59 PM
I did for both my car and my father s mini van.
the tech who did my plugs 13 ~ k miles ago didnt apply ****, and it was really a bitch for me to try to get it off .... I was actually afraid that I might break something then my engine will **** .... lucky nothing happen.
Old Apr 23, 2007 | 05:32 PM
Nubo's Avatar
Lubricious
Highly recommended. The only problem would be if you gooped on so much that it got onto the center insulator. Use a small amount; about the size of a small pea, and work it into the sparkplug threads. I usually leave the last couple of threads dry at the end of the plug to make sure I'm keeping the stuff clear of the business end.
I learned my lesson on my Miata when I got a plug stuck in the #1 cylinder. I accumulated about 50,000 miles while thinking about what I wanted to do about it. In the end I sold the car Anti-seize from now on.
(I did warn the buyer though.)
The other useful salve for sparkplugs is dialectric grease. Apply between the outside insulator and the ignition wire boot. Helps seal against moisture and aids in removal.
RevMeHarder
Jun 1, 2026 02:30 PM
DylanForbes
25
Oct 31, 2017 05:47 PM
iphil
Sep 21, 2015 10:49 PM
Forevermore
Sep 20, 2015 01:04 PM
Vedivan1
Sep 18, 2015 12:39 PM
