Request the RX8 Club Approval
Old Apr 11, 2007 | 10:55 PM
Tyguy's Avatar
Alright, after looking around ebay for a while I narrowed my search to the following:
Subs
Box
Amp 1
Amp 2
You may of noticed there are two amps there, basically because im not sure if I should stick with that 400W one or try the more powerful one. As you can tell I have never installed an amp before so bare with me.
Anyways, does this for the most part look decent? And where do I research the necessary wires I will need for installation?
Old Apr 12, 2007 | 08:50 AM
Tyguy's Avatar
Old Apr 12, 2007 | 09:08 AM
Thack's Avatar
Gives it a nice clean look. Where are you mounting the amps? You are going to need a Line Out Converter so the amp can receive sound from the radio.
Old Apr 12, 2007 | 10:07 AM
Tyguy's Avatar
ya, im not sure what else I need as for wires and other stuff, i was planning on mounting the amp in the lowered part in the trunk
Old Apr 12, 2007 | 12:39 PM
WikkedOne's Avatar
Deals on wheels
Get the more powerful amp definatly but DO NOT get a refurbished one.
Other than that everything looks good.. just do alot of research on here and make sure you have everything you need before you start.
Old Apr 12, 2007 | 01:00 PM
Tyguy's Avatar
I cant seem to find the more powerful one non-refurbished...anyway, this cheaper one is 400 Watts, isnt that more than enough?
Old Apr 12, 2007 | 01:52 PM
Xoq's Avatar
Xoq
look at the recomended power for the subs 250 watts RMS. if you run two subs you will go to 2 ohm load and split the power between the subs. so you want an amp that puts out 500 watts class D at 2 ohms.
http://mobile.jlaudio.com/products_s...php?page_id=35
Thack's Avatar
I believe it is. If the person on ebay has ALOT positive feedback and little to none negative then i shouldnt matter. Definately do your research on here and feel free to ask questions. This stuff aint too tough.
Old Apr 12, 2007 | 01:57 PM
Tyguy's Avatar
the only reason im hesitant is that its very cheap for a 400 Watt amp
Old Apr 12, 2007 | 02:02 PM
Xoq's Avatar
Xoq
instead of ebay why not just go to the guys website i have bought from them b4
http://www.sonicelectronix.com/
the 60o watt matches your needs better
http://www.sonicelectronix.com/item_...r+KX600.1.html
Old Apr 12, 2007 | 02:11 PM
Tyguy's Avatar
what is the next best thing besides the kx600? trying to get below 300 bucks
Old Apr 12, 2007 | 02:55 PM
Xoq's Avatar
Xoq
the alpine has LOC's built in which, all though i can ot speak to their quality. i have seen one install in an 8 with alpine bass amp.
http://www.sonicelectronix.com/item_...+MRP-M650.html
philip53
Jul 30, 2015 04:18 AM
Tyblat
9
Jul 29, 2015 07:20 PM
Love_Hounds
Jul 23, 2015 12:44 PM
JPCZONE
Jul 21, 2015 12:02 PM
