How often to change trans and diff fluid if using synthetic?
Old Apr 5, 2007 | 06:35 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
How often should I or do you change the transmission and differential fluid if one is using synthetic?
I am going to be putting Royal Purple Max-Gear in soon with new crush and fill washers.
The manual recommends every 30K miles (or X months), but that is with the stock fluid. Do I follow the same schedule with synthetic?
Old Apr 6, 2007 | 01:32 AM
I change mine every spring before track season.......
Old Apr 6, 2007 | 10:51 AM
hmm, I've got about 20K on mine....I'll probably change it soon. Oh, and Royal Purple ROCKS...
Old Apr 6, 2007 | 11:06 AM
ZoomZoomH's Avatar
Mulligan User
you probably *can* go longer on synthetic gear oils (same reason as motor oils), but i think sticking to 'regular' replacement schedule would be fine.
Old Apr 6, 2007 | 11:09 AM
Jax_RX8's Avatar
Got Another Rotary
30k max, even for synthetic.
15k for low mileage driving or tracking/auto-x
Old Apr 6, 2007 | 01:26 PM
Crush Washer Info
Old Apr 6, 2007 | 01:31 PM
Originally Posted by Jedi54
One of the many useful and crucial posts/threads on this Site.
Thanks for the answers so far. I didn't know if I treated synthetic diff and manual trans fluids the same as synthetic oil in that I can go longer intervals between changing.
Most likely it is fine going longer intervals, but it looks like sticking to the 30K mile schedule is a good bet. I don't autocross or run tracks very much so that really isn't a factor for my 8.
nowakm99
Oct 9, 2015 07:10 AM
Anthony Kevin
Sep 7, 2015 07:36 PM
Cookingislife1226
Sep 5, 2015 03:38 PM
wayloco
Sep 1, 2015 09:03 PM
