Knock Sensor Procedure?
Old Feb 21, 2007 | 01:26 PM
turbine's Avatar
4th Year runnin
Question Knock Sensor Procedure?
Can anyone tell me if they had good results from removing the Knock Sensor? Racing Beat seems to make a note about it, but no place really significant on this forum. I am getting the infamous pinging or knocking(marbles). I am in the dark on how to hang the sensor without mounting it to the car. You have to leave it connected, but not mounted. Seems like that would vibrate around, triggering the sensor to think the engine was knocking.
Old Apr 22, 2007 | 12:45 AM
dastallion951's Avatar
if u disconnect the knock sensor u have no way of knowin if ur detonating............that knock sensor is basically a red flag sensor.......u remove that u can kiss ur motor goodbye after one of two misfires guaranteed...........u wouldnt remove ur air filter n drive it daily......?? but good luck
Old Apr 22, 2007 | 01:23 AM
you seem knot to have a kclue.....
Old Apr 22, 2007 | 05:38 PM
It's one thing to unbolt it in controlled conditions, it's another to drive around with it that way
don't come crying to us when you're engine is dead ...
Old May 2, 2007 | 03:51 PM
turbine's Avatar
4th Year runnin
I must have mis-understood the RB website. They are pulling the sensor. Will check the site again. More or less trying to trouble shoot a problem. I would connect it back, just wanted to see if it was creating symptoms or problems. Thanks for your O so pompus inputs. Always enjoy them.
Old May 2, 2007 | 07:07 PM
You are most welcome
try wrapping it in a rag with a piece of duct tape to hold it in place
Old May 2, 2007 | 09:00 PM
RxJaye's Avatar
The knock sensor controls ignition timing, pinging causes it to dial the advance back to stop detonation. If you have noise in your engine, i assure you it is not the knock sensor. If you dont know how a car works, dont play with it. It makes it a lot harder on the person who has to fix not only whats wrong but what all you screw up.
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
tjohnmeyer
Sep 28, 2017 05:03 PM
Luke.s
Sep 30, 2015 05:57 PM
