Power Steering Failure
#272
2 Tone...Low Drone
I had the power steering issue as well about 2 weeks ago. We cleaned the 2 plugs by the air box and it didnt work. I then unplugged the connector that plugs into the actual power steering ECM and cleaned it. Once I put it back on, I have not had a single issue with the power steering.
#275
shovin' into overdrive...
on
Even since I got my car back from the dealership after they swapped my engine a year ago, there has always been a power steering issue. Whenever I turn left, the turning is nice and smooth, but when i turn right, there is constant shudder. This would generally only occur when the engine was cold. After the car would warm up, the steering would return to normal. Left or right.
Last week i got my first power steering warning light and when the car would start cold, there would be zero power steering. After the car got warmed up, i would turn the car off and on until the power steering would come back to life.
I removed the air intake, I did notice that there was some coolant boil over residual. I then proceeded to remove the wiring harness and cleaned the connectors with some electrical connector cleaner. After i reinstalled the wiring harness, so far, there has been no more power steering lights. Now my left turns are back to normal and the rights have a slight shudder again.
Next, I went to clean the power steering control module connectors under the PCM. No change. The alternator is good. I guess my next step is to replace the $100 wiring harness. Thoughts?
#276
2 Tone...Low Drone
Update: So the power steering failed again after I cleaned the connectors. before it went out, I was able to turn to the left TOO easy and to the right had some resistance. Then the entire power steering failed. I replaced the power steering ECU but it went out 2 days after that again! So I put my old ECU back in and replaced the harness for the power steering. Now the power steering works better than ever and I have not had a single issue since.
#277
That's exactly what was happening to me, but I never replaced the ECU thanks to the posts here. Most of the time is the harness. Hope you were able to get a refund for the ECU!
#278
2 Tone...Low Drone
Ok...I have a huge problem...power steering went out AGAIN!!! I have replaced the ECU and the Harness and still it fails about a week later. I would say it is the rack however with it being an intermittent problem, it comes and goes, I cant think it would be the rack. i would think if it was hardware like the rack, it would be out all the time once it fails. But with it being a problem that comes and goes throughout the day, I am still saying its electric.
#279
on
I also replaced my harness with a new one and it still failed a couple of days afterwards.
One thing I noticed, when PS does fail, all I would have to do to get it to work temporarily is turn off the engine. Open hood and slightly nudge (or wiggle) the top 3-prong torque sensor wire (near the connector) on the power steering harness. And then when I turn on the car, PS will work for a day or so. You might want to try this. I have a MS CAI with the bottom intake tray removed, so my harness is easily accessible.
I got fed up having to keep doing that, so back in August I ended up taking it to the dealer to get it looked at by one of their rotary techs. The problem was so intermittent, even he couldn't really pin-point what exactly was causing the problem. Went there several times back and forth, until "magically" somehow it no longer comes on, and has been working fine for the past couple of months. I only ended paying the initial diagnosis fee of $89, thank god, even though he spent hours on it.
At first he thought it was a grounding issue as it was a common problem with other Mazda models. So he sanded down the cross-bar to bare metal where the main ground is connected. Then tied in all the grounds on the harness together to the main ground wire (see pic below). It did work for a couple of days, that is until the dreaded PS light came back on.
Then he told me to bring it in when the PS light is on so he can pull a code from the ECU. Which I did a couple of times, but whenever he would turn it on PS would be always be working. He was able to pull a code once in one of my visits, came up as "intermittent torque sensor failure on the PS rack". But when he tested the sensor on the rack as well as everything else, ECU, harness, it all tested out fine. He wanted me to bring it in again when the PS light came on again so he can pull the code again to confirm. Of course, whenever I would bring it to him and turn off the engine, he'd start it and the power steering would work, and he'd be unable to pull any codes. I did bring it to him with the car still running, but he'd always be busy and unable to look at it right away, so I'd end up turning the engine off. So damn frustrating!
On my last visit, I re-iterated to him that I am able to wiggle the torque sensor wire on the harness to get it working temporarily. So he got me to turn the steering wheel while he wiggled the harness. Low and behold, the stirring wheel jerked to one side, but the PS light didn't come on. He ended up just zap strapping the harness in place to secure it's position, and he then put dielectric grease on the prongs on both top connectors in the harness.
That was in Aug. and since then it's been working fine without a failure yet. I was just about to buy a refurb. rack off eBay too, but the tech told me to hold off until it was completely evident that it is a rack problem, and not waste money by "throwing parts at it", hoping to solve the problem. He said it is very rare for the PS rack to fail, and he's never had to replace one.
#280
2 Tone...Low Drone
Thanks a lot for this post man! I went home that night and secured the harness connectors even more and wouldn't you know it, power steering is back and working great in both directions!!! I guess as you drive they shake loose and lose power steering. Its working like a champ now! Thanks man!
#281
I tried searching but is there a DIY on replacing the wire harnesses?
After my engine was replaced my PS has been perfect and the dealership said if the PS doesn't act up after a week it's most likely the harness because they cleaned the connectors when replacing the engine.
I was also told if your battery terminals are bad or if the battery isn't properly secured, that that would also cause the PS to act up.
#282
Surf Hard, Drive Hard
on
Dave
#284
2 Tone...Low Drone
There honestly is not a DIY needed for the harness. Its about 3 feet long with 4 connectors...there honestly isn't a way to mess it up...all the connectors will only fit in the right place and you can see the entire harness before you even start. Only difficult part, if you don't have skinny hands, is getting your hands in some of the places. I am sure it would be easier if you put the car in the air so the bottom two connectors were more accessible...but I was lazy and just went at it from the top and just scraped my hands a little
