Got My AP Racing Brakes for the RX8!
Old Jan 14, 2007 | 01:03 AM
Silverarrow's Avatar
OldeSpeede, Inc.
Thumbs up Got My AP Racing Brakes for the RX8!
Well, I finally got word that the kit was out and went down to STILLEN to pick up my AP Racing Kit! I still have stock wheels but have a bolt on spacer that will give me enough clearance for now until I upgrade to wheels with more brake clearance.
Here's a few shots after opening one of the boxes:
1. Full Box Shot - Everything in one of the two boxes for the kit (left and right)
2. Rotor and caliper face close up
3. Profile view of rotor and caliper, look how beefy that thing is
4. Mounting bracket for the caliper - Anodized aluminum with steel thread inserts
I also was surprised that everything was assembled (minus the lines being installed on the caliper. It looks like everything should be a simple remove and replace (brake bleeding will probably be the hardest part!
I planned to put the kit on this weekend, but might not have time (Chargers Playoff Game tomorrow!!!) I'll definitely post up picks once I do get it going.
Attached Thumbnails Got My AP Racing Brakes for the RX8!-apkit1.jpg   Got My AP Racing Brakes for the RX8!-apkit2.jpg   Got My AP Racing Brakes for the RX8!-apkit3.jpg   Got My AP Racing Brakes for the RX8!-apkit4.jpg
Old Jan 14, 2007 | 01:14 AM
foo77's Avatar
4th batch : Apr 03'
congrats can't wait to see with your 8
Old Jan 14, 2007 | 01:50 AM
cavemancan's Avatar
The forgestar be with you
Don't forget about the torque settings...I maid that mistake and snapped one of the caliper bolts.
1st set of Caliper bolts - 21 to 34 ft/lbs
Note: These are the bolts that you need to take off to get to the pads. I honestly dont remember the torque for the other bolts but if you search on the forum there is a site that has the Rx-8 shop manuel online.
Good wrenching!
Old Jan 14, 2007 | 02:43 AM
post the weights
Old Jan 14, 2007 | 02:49 AM
NgoRX8's Avatar
SICKK!!! i wanted these too.. haha
Old Jan 14, 2007 | 11:56 AM
gr8rx's Avatar
Originally Posted by TeamRX8
post the weights
agreed......important info for people trying to lose rotational weight......
Old Jan 14, 2007 | 11:57 AM
RA-Eight's Avatar
Scuderia
Lucky! Yeah don't forget to weigh them if you have a chance!
Old Jan 14, 2007 | 01:04 PM
RoXanneBlack8's Avatar
stop flooding ur engines
dont forget to flame him for buying a bbk like you all did with me
Old Jan 14, 2007 | 01:07 PM
NgoRX8's Avatar
...ok...
Old Jan 14, 2007 | 01:08 PM
it just depends which BBK you get, we don't have enough info yet to justify unleashing the flamethrowers ...
although having to go use spacers to clear the OE wheels is one bad mark for a street car ...
Old Jan 14, 2007 | 01:19 PM
OldeSpeede, Inc.
I will definitely post the weights. As far as the spacers, that is only temporary. Once I get new wheels they will be properly sized to accept the kit.
Old Jan 14, 2007 | 01:32 PM
it's not temporary for people who want to use OE wheels, how thick do they need to be. I recall Stoptech requires a 15mm spacer, which in turn requires longer wheel studds in the front hubs
Old Jan 14, 2007 | 02:25 PM
grats on the BBK. it looks pretty hot! when are you planning on getting the new wheels?
Old Jan 14, 2007 | 02:46 PM
lazi's Avatar
drivelinestore.com
looks nice!
Old Jan 14, 2007 | 02:52 PM
eastsurf84's Avatar
Just curious how much a set of those beauties run for?
Old Jan 14, 2007 | 02:54 PM
RotorManiac's Avatar
Absolute Rotary Madness
very nice, I'll get the same kit soon, due to financial reasons I postponed it... ap racing is, if not the best, one of the best brake companies out there.... re amemiya uses these for his cars too. I'd like to know the weights too and ...price please (if thats ok with you to tell)
do you know if they fit a +38 offset? thanks
Old Jan 14, 2007 | 05:05 PM
They are around 2500.
I'm surprised they designed the where you have to use wheel spacers on stock Wheels.
Do you have an AT with 16" wheels.
Old Jan 14, 2007 | 05:58 PM
NgoRX8's Avatar
he has a manual. this just means u gotta get new wheels. haha. i think a 15 mm spacer is pushing it...
Old Jan 14, 2007 | 07:12 PM
wtf
Old Jan 14, 2007 | 10:15 PM
OldeSpeede, Inc.
Ok, I haven't installed them yet, but I did get weights for everyone:
AP Racing CP6600 Caliper with pads, mounting bracket and hardware: 9lbs
330mm 2 Piece Cross Drilled and Slotted Rotors: 17lbs
Also, the spacer I am currently using is a bolt on unit, so longer wheel studs are not necessary.
I will definitely post pictures of the install.
RotorManiac: The price of the kit is $2376.75 and you can check fitment with your wheels using the attached profile.
File Type: pdf
Old Jan 14, 2007 | 10:20 PM
BlueRenesis82's Avatar
Registered Tracker
no. you are not using your for track work which=lame
Old Jan 15, 2007 | 02:18 AM
gr8rx's Avatar
racingbrake owns..........the fronts only weigh 10lbs more than racingbrake bbk
Old Jan 15, 2007 | 09:47 AM
^can you be more specific? which bbk do you mean?
silverarrow, thanks, much appreciated... one more thing, is your kit called AP4600?
can't wait to see them on your car...
Old Jan 15, 2007 | 02:48 PM
holyt sh-t that's a big spacer, don't forget to add that weight on too. That caliper sticks out a mile. The standard RacingBrake BBK caliper only protrudes 1.1" from the rotor face, the Enkei wheel version protrudes about 0.75"
RacingBrake BBK
http://www.racingbrake.com/RX8_s/3254.htm
http://forums.racingbrake.com/viewtopic.php?t=39
http://forums.racingbrake.com/viewtopic.php?t=45
http://forums.racingbrake.com/viewtopic.php?t=64
Old Jan 15, 2007 | 05:58 PM
"no. you are not using your for track work..."
when did u get this idea?
i am gonna go BACK to the road course this summer....
tell me more about what i plan to do with my own car........go on
