Can someone exlain wheel offsets?
Old Dec 30, 2006 | 12:59 PM
romycha1's Avatar
I'm just a little confused about this.
Zero offset is the middle of the wheel, and (for example) +45 offset would be 45mm toward the outside of the wheel, right?
And the lower the offset, the wider the stance would be....
Is that right? I know it's a simple idea, but for some reason I just can't get it...
Old Dec 30, 2006 | 01:11 PM
Easy_E1's Avatar
Try this LINK .
I found it very informative.
Old Dec 30, 2006 | 01:30 PM
The Mighty Red's Avatar
Rally Car Racer
Originally Posted by romycha1
And the lower the offset, the wider the stance would be.... Is that right?
You got it right.
RX8 OEM wheels have an offset of 50mm. So if you get wheels that are the same width an an OEM wheel - with an offset of say 38mm, the outer wheel (the tire) will be moved 12mm to the outside which is just less than 1/2 an inch. These would fit just fine I would think.
Now add a little complexity. Suppose you get a wheel that is 1 inch (25mm) wider than OEM and the offset is 40mm. How much further out will the wheel be than OEM?
Add half of the additional 25mm width to the outside edge of the tire (12.5mm) then add 10mm for the offset -- the result is the new wheel's outer edge will be moved 22.5mm to the outside. Almost an inch.
Here's the interesting part - the inside edge of the wheel will only be 2.5mm closer to the body. Do you see why? 12.5mm additional width minus the 10mm change in offset.
Old Dec 30, 2006 | 02:50 PM
Take the width of the wheel in mm ....divide in 2 gives you the starting point ( you only need to think about this if you change wheel widths)
Zero offset is at that #...IE CENTER
+ offset is moving the mounting face outwards by (+offsett#) of mm
-ve offsett is moving in from center that (-offset#) of mm
So stock is an 8" rim...with the mounting face 50mm out from the center...or about 2"
Old Dec 30, 2006 | 03:20 PM
romycha1's Avatar
Thanks guys... I was jsut reading other posts and it got me thinking. Also for my own knowledge since I will be getting new wheels soon.
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
duworm
Oct 1, 2015 04:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
