1 inch spacers
Old Dec 20, 2006 | 01:05 AM
mike0615's Avatar
Dooky Booty
1 inch spacers
I put one inch spacers on and now I get fender rub in the back. front seems ok. you guys think I should roll the fenders? anyone here with experience with that? help a brotha out please.
Old Dec 20, 2006 | 01:09 AM
NgoRX8's Avatar
what are the specs on your wheels and tires? and how often do you rub?
that will determine if fender rolling will actually fix the problem.
Old Dec 20, 2006 | 01:15 AM
mike0615's Avatar
Dooky Booty
stock wheels. just spaced it out 1 inch on each side. i did a like 2 inch drop though
Old Dec 20, 2006 | 01:44 AM
LionZoo's Avatar
road warrior
Let's have some fun with math. An inch is 25.4mm. The 9.5 wide 45mm offset RP-F1s are very close to rubbing. 0.75 inch plus 5mm are on the wheel side, which equals about 24mm of extra width out of the fender well. You're less than 2mm more outboard than those guys, but the guys that run that wheel tend to also run negative camber. Nonetheless, I feel should be fine if you roll your fenders. If you really want to be safe, get an alignment and make sure you have at least a degree of negative camber.
Old Dec 20, 2006 | 02:32 AM
mike0615's Avatar
Dooky Booty
cool, gonna get a heat gun and a bats, i'll try to get some pics up tomorrow.
Old Dec 20, 2006 | 02:50 AM
NgoRX8's Avatar
what!!?? you are actually going to use that old, freakin scary method to roll your fenders... oh boy...
well, good luck...
Old Dec 20, 2006 | 02:55 AM
mike0615's Avatar
Dooky Booty
wha??!! is there better way? tell me before i break something.
Old Dec 20, 2006 | 04:10 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
hopefully your paint dun crack man.... GOOD LUCK!
Old Dec 20, 2006 | 04:23 AM
NgoRX8's Avatar
there is a tool that is used to roll fenders. it is attached to the center hub and from there rolls the fenders.
maybe you should take it to a shop to do it...
Old Dec 20, 2006 | 07:20 AM
ac3mastuh's Avatar
Got Ings?
autobacs will do a fender roll, they're in stanton
Old Dec 21, 2006 | 04:48 AM
mike0615's Avatar
Dooky Booty
found a fender roller. got it done. fits great. i don't have a cam yet, but will post pics soon. paint is fine. i had to get a heater and 2 blow dryers going on it to keep it from cracking. looks very nice, nice aggressive stance. handling is much better too. i can really feel it on on and off ramps. can't really push it like how i would wnat to like if i was on the track, but i can feel going at a spirited pace that it grips and holds better. love the up grade, didn't cost too much but was something i could immediatly feel.
92trbolzr
May 18, 2025 09:04 AM
theblinkof
Oct 4, 2023 05:24 PM
duworm
Oct 1, 2015 04:57 PM
Rote8
Sep 22, 2015 03:43 PM
