Kumho V710 245/35ZR18
Old Nov 18, 2006 | 07:19 AM
rotorpr's Avatar
I completed my first year in Road Racing with my Falken Azenis 615 but for next year I want to get into the real thing with some Kumho V710.
Do somebody know if the Kumho V710 245/35ZR18 will fit well in my Enkei RP-02 (18 inch)?
Old Nov 18, 2006 | 09:54 AM
that depends on the width, which you didn't specify
Old Nov 18, 2006 | 03:29 PM
rotorpr's Avatar
The width is 7.5 .
Old Nov 18, 2006 | 03:58 PM
they're a real b-tch to mount on 8", I probably wouldn't recommend it
Old Nov 18, 2006 | 04:26 PM
rotorpr's Avatar
Well if that is the case I would need to get other wheels. What would be a good bundle with the V710? maybe go lower to 17 inches
Old Nov 18, 2006 | 06:52 PM
rotorpr's Avatar
Or what about the Hoosier A6 225/40ZR18 with the Enkeis?
Old Nov 18, 2006 | 07:11 PM
You might want to ask around about the 710's on a road coarse. They supposedly get kinda greasy when they get real hot.
Old Nov 18, 2006 | 09:18 PM
that Hoser size will fit fine, but you'll probably want the R6 unless you're a smooth driver running short sprints in cool weather. A6 is an autocross compound intended to heat up quickly on short runs
Old Nov 19, 2006 | 06:07 PM
olddragger's Avatar
Dont forget the workhorse of R compunds --the Toyo RA-1'S. Many differant sizes. But you need to get wider wheels than 7.5. for any tire on the rx8. at least an 8" wheel.
on the road course a shorter tire 40 series 17" or a 35 series 18" plus light weight wheel/tire makes a huge differance. do some reading
olddragger
Old Nov 19, 2006 | 06:18 PM
BFGoodrich had re-introduced a new version of the g-Force R1 DOT-R tire
http://bfgoodrichtires.com/overview/...e-r1/3824.html
Old Nov 19, 2006 | 09:02 PM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
Originally Posted by rotorpr
The width is 7.5 .
The Boxster guys and VW R32 guys run those tires on 18X7.5" wheels all the time. Your tire guy will hate you but they will fit with some work.
Old Nov 19, 2006 | 09:43 PM
mwood's Avatar
What do you mean by "road racing"? Lapping days or racing? 20-30 minutes at a time or more?
In any case, the autocross trick of fitting as wide a section as possible on a given rim width doesn't translate to track use, imho. The loss of turn in and "squirm", not to mention loss of longitudinal contact patch, all are issues when you start compromising the sidewall profile. Better to be a little more realistic and stay close to the manufacturer's reccomended rim specs. I'd run the Hoosier R6 in a 225 section width, personally.
Old Nov 19, 2006 | 09:45 PM
yes, getting it mounted and being the best choice are two different things
Old Nov 21, 2006 | 06:24 PM
rotorpr's Avatar
mwood:
Attach a layout of the road course; we normally do 10 laps per heat and we have one practice heat and three official heats . for a total of 40 laps per day.
Attached Thumbnails Kumho V710  245/35ZR18-pisp-road-course.jpg
Old Nov 21, 2006 | 06:56 PM
mwood's Avatar
mwood:
Cool, you run in Puerto Rico
Given the course layout, about 20 minutes on course per heat, and the fact that you're going 40 laps a day, that the R6 Hoosier would be a good tire for you to consider, in a 225 section width. That way, you don't have to get new rims, if you don't want to. I'd bet the Kumhos would be every bit as good for your use, but then you'd need new rims to fit the 245 effectively.
Fair!
Jul 28, 2006 08:46 PM
pcimino
RX-8 Racing
19
May 24, 2006 09:37 AM
CRX Millennium
RX-8 Racing
39
Oct 18, 2005 03:01 PM
ULLLOSE
RX-8 Racing
20
Mar 16, 2005 09:52 PM
