An RX-8 that won't go?
Old Nov 9, 2006 | 02:07 PM
bigboss's Avatar
I need your help guys. My RX-8 will start/idle and rev to the moon. Problem is that (hot or cold) there's a flat 'spot' (more like a field) between 5 and 7K. It's like the engine hits a wall ( ) at about 5100 and if I keep it pinned it will gradually climb out and act as if nothings wrong after 7K! I tried the reset with the odometer trick but can't get the reset with the brake pedal to work. I have MIL on but that only happened today. Car has been running like this for a few weeks now. Don't know what the code is yet. I look forward to your help.
Old Nov 9, 2006 | 03:41 PM
dmc27's Avatar
doin' the bull dance
Year, trans, etc??
Have you taken it in at all?
(couldn't get the brake pedal reset to work either. what a PIA)
Old Nov 9, 2006 | 03:46 PM
shaunv74's Avatar
Power!!
Something is definitely up. I would take it to the dealer ASAP. Do you have any major mods that would be messing with ignition or the computer.
Old Nov 9, 2006 | 04:27 PM
Red Devil's Avatar
If your car hasn't been in for the Recall, now would be a good time.
Old Nov 10, 2006 | 02:00 AM
If not CAT bad coil.
Old Nov 10, 2006 | 08:52 AM
bigboss's Avatar
It's a 2004 stick shift with only 16,000 miles. Bone stock, no mods whatsoever (yet). Haven't taken it to dealer yet (like many of you I like to do the work myself). What would the dealer recall involve? I suspected the Cat also. Would a bad coil (or cat for that matter) react only on a very specific RPM range? Is there a trick to read the code(s) from the ECM? My OBDII scanner obviuosly won't work with the new CAN system.
Old Nov 10, 2006 | 09:31 AM
ken-x8's Avatar
You're still under warranty, so the simplist trick to read the codes would be to take it to a dealer.
Where are you located? I'm in Northern Virginia and I've got a Harrison CANScan. But with the warranty, you're eventually going to wind up at a dealer.
All of the recall notices and service bulletins are here:
http://www.finishlineperformance.com...ins_index.html
The top two red ones describe the current recall. The green one just below that describes the extended power train warranty.
Ken
drebbrnator
Dec 27, 2018 07:02 PM
Ian_D
Rotary Swaps
26
Jan 21, 2017 02:23 PM
Modern2Strokez
Aug 16, 2015 01:07 AM
Davey's RX-8
Jul 28, 2015 12:13 PM
