e-brake light
Old Nov 6, 2006 | 12:00 AM
ca18detsilvia's Avatar
e-brake light
hey guys, the past few days my e-brake light has been coming on and staying on when the e-brake is fully down, the break is not draging or anything, the light is just coming on, one time it came on when i went fast around a corner, anyone know what may be causing it, its just annoying
Old Nov 6, 2006 | 12:32 AM
Old Rotor's Avatar
There is a switch connected to the e-brake, its loose, bad or needs adjustment. Remove the cover its an easy fix or might be covered under warranty. It could be your pads, how many miles do you have?
Old Nov 7, 2006 | 01:48 PM
Rhythmic's Avatar
Laid back in the pocket
I had the exact same thing happen. The light came on right after going around a corner fast. The light stayed on intermittently for about a week. It turns out I need new pads. After new pads installed the light went away for good.
>Check your pads.
Old Nov 7, 2006 | 02:08 PM
yep get your pads and fluid checked
Old Nov 7, 2006 | 02:19 PM
dupa12345's Avatar
new pads .. mazdas dumb way of telling you that
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Jun 14, 2022 08:32 AM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Evan Gray
Sep 26, 2015 12:30 PM
