FAQ Flooded engines
Old Nov 3, 2006 | 12:14 PM
hyperlitenerd's Avatar
captin safety
FAQ Flooded engines
Since I was unable to find a thread that directly disccused this...
1. What will cause the engine to flood?
2. How can I avoid this?
3. Oh Noes! my engine is flooded, is there anything I can do to deflood it?
4. Are there any mods to help prevent this problem?
Old Nov 3, 2006 | 12:19 PM
expo1's Avatar
He's as bad as Can
I guess this subject will never go away.
https://www.rx8club.com/series-i-trouble-shooting-95/
Try Sticky #1, all the answers are in that thread.
Old Nov 3, 2006 | 12:31 PM
captin safety
I was hoping to put all of the important things in one simple thread, not 93 pages... but thanks for the link
Old Nov 3, 2006 | 12:41 PM
expo1's Avatar
He's as bad as Can
This is all you need to know.
Do not shut off a cold engine and let anyone that has access to the car know that also.
That has worked so far during my 78,000 flood free miles
Old Nov 3, 2006 | 02:01 PM
sonicblue6's Avatar
My seller called me frantically a couple hours after I picked it up. He was like, "I would've been up all night worried if I hadn't called you!"
If you "DOH!" and flood it, push the gas pedal to the floor and try repeated cranks of the key lasting about 10-15 seconds for a couple minutes and see if it starts. If it does, thank your lucky stars and get it nice and hot before shutting it down again.
Old Nov 3, 2006 | 02:41 PM
dmc27's Avatar
doin' the bull dance
owners' manual
Old Nov 3, 2006 | 03:08 PM
captin safety
How would you know if you flooded it before you tried to start it up again??
Old Nov 3, 2006 | 03:43 PM
sonicblue6's Avatar
If you just did a quick move/short drive/cold shut-off and thought, "doh, I shouldn't have done that!", or any time the car doesn't crank right up, odds are strong you flooded it. It's important that, if you think you may have, that you do NOT try to crank it normally, as more fuel will get injected with each crank. As soon as you suspect, floor the pedal and try to crank.
rotarywanker
Dec 8, 2022 05:56 PM
vapor2
Nov 3, 2020 03:38 PM
RXeckless
Aug 16, 2015 12:51 PM
Supernaut6
Aug 11, 2015 07:28 PM
thedragonrotar
Jul 22, 2015 08:46 PM
