Oil consumption??
Old Sep 2, 2003 | 08:57 PM
RXg8tor's Avatar
Oil consumption??
I just turned 1100 (hard driving) miles, and I've been checking the oil level frequently. It hasn't moved!!! Is this right?
Old Sep 2, 2003 | 08:58 PM
Puppy1's Avatar
Pure Unadulterated Fun
Mine didn't require any oil until 2,500 miles. You got a good one.
Old Sep 2, 2003 | 09:35 PM
Zoom49's Avatar
At my 2,500 mile oil change mine was 1/4 below the full mark.
Seems to not use use as much oil as my other rotarys.
Old Sep 2, 2003 | 09:38 PM
jd62's Avatar
Old Fart
I have an early VIN, and believe I need a new oil pan with better baffling, so my oil level light comes on at high speeds if it's down by 1/2 quart or so. I put in a 1/2 quart at 1300 miles, and the other half at 2600 miles.
Old Sep 3, 2003 | 09:15 AM
jtimbck2's Avatar
My dipstick was down about 1/3 of the way between the full and low marks at around 1000 miles, so I added half a quart. Unfortunately, I don't think it needed quite that much, because now it's over the full mark. I should have added less.
My oil light has never come on.
Old Sep 3, 2003 | 09:55 AM
boowana's Avatar
Half a quart
Mine used a half a quart at about 2000 miles. Apparently, if youdrive the car ahrd, more oil is used for the apex seals and is computer controlled.
Old Sep 3, 2003 | 10:16 AM
daedelgt's Avatar
Makes sense that it uses less. Previous rotarys did not regulate the flow as much, and as a precaution, dumped more oil in than nescesary.
Old Sep 3, 2003 | 10:25 AM
RX8-TX's Avatar
Senior Geek
Over 770 miles and not a single drop of oil has gone down....
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
