Type pressure help
Old Oct 21, 2006 | 02:10 PM
HKS17's Avatar
Type pressure help
Whats the correct psi for MM RX8 that comes with 18inch Bridgestone Potenza?
Pls kindly advise. Mine currently runs on 35 psi.
Old Oct 21, 2006 | 04:44 PM
d j's Avatar
d j
hukbong himpapawid
I'm running 37.5 (f)/38 (r) psi of nitrogen on mine. I believe, 36 psi is the recommended pressure from the factory.
Old Oct 21, 2006 | 08:49 PM
CoupeM's Avatar
Night Rider
Wa..so high..I running on 32psi only.
Old Oct 22, 2006 | 07:43 AM
morganoh's Avatar
Theres a tag either at the door or at the door frame. Just open the both the front and rear door , should be able to find it.
It indicates the recommended tire pressure for both front and rear, when the car is at full load or when the car is carrying min load.
Sorry I forgot the numbers. so but u should not have any problems finding this tag.
Old Oct 22, 2006 | 08:36 AM
foo77's Avatar
4th batch : Apr 03'
same as CoupeM with 32psi you can check it in manual
Old Oct 23, 2006 | 02:29 AM
RX8ster's Avatar
Red Devil
Mine's riding on 36psi, as recommended by Goodyear.
http://www.goodyear.com.sg/catalog_s...AME=Eagle%20F1
cliffkemp
Dec 24, 2024 10:48 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Digitz0070
Oct 7, 2015 12:43 PM
jDt!
Oct 2, 2015 04:04 PM
He||hammer
Sep 29, 2015 09:40 PM
