fixing rear fog lights
Old Oct 16, 2006 | 10:37 AM
mkl22's Avatar
Any other shops other than MM has very good experience with the rear fog lamp? Looking for a fast fix, rather than be a guinea pig for some Accessory shop. cause mine is PI.
Old Oct 16, 2006 | 10:41 AM
Yellow Cab's Avatar
rear fog lamp from MM is normal bulb. Try to get LED 1.
Old Oct 16, 2006 | 11:43 AM
mkl22's Avatar
actually prefer incandescent blubs. LEDs are a bit too ex for me and somehow doesn't save much.
Old Oct 16, 2006 | 11:39 PM
Emperor's Avatar
aka Spectre
So the haze is that bad.
Old Oct 17, 2006 | 02:14 AM
mkl22's Avatar
went for a drive up north. and during heavy rains, i can hardly see the car in front of me. So think that a rear fog kinda useful, it also adds a bit of color to the otherwise black 'bum'
Old Oct 17, 2006 | 06:51 AM
c h o x's Avatar
Stock...
Inter moonson season is approaching. Based on the weather report, there's an indication of of the onset of North Easterly winds. Could potentially clear our haze problem...save some money buy better brakes...even if you can't see, can still stop in time.
Old Oct 17, 2006 | 07:03 AM
mkl22's Avatar
stock brakes quite decent la. tires are also new. rear fogs are also a good weapon against those non projector type illegal HIDs.
Old Oct 17, 2006 | 09:51 AM
morganoh's Avatar
The brightness of the LED ones will never be close to the Original Normal Bulb rear Fog light.
its Tested during one of the trips to Malaysia together with JetBlast. and It was raining very heavily. and the Only car that can be seen is the one with the Mazda Bright Red Rear fog light.
Old Oct 17, 2006 | 08:23 PM
wen pin's Avatar
pardon my ignorance. but is the rear fog lamp LTA compliant?
Old Oct 18, 2006 | 12:46 AM
morganoh's Avatar
I'm not sure. cos Mazda Motor did not say any thing.
Old Oct 19, 2006 | 07:12 AM
c h o x's Avatar
Stock...
Think it is...Some Opel car comes with rear fog lamp as well. Kena caught say it's from MM lor...
Old Oct 20, 2006 | 12:21 AM
mkl22's Avatar
rear fogs
Decided to DIY. finished installing the light behind. next is the wirings.
will only use fogs when the visibility is bad la. I know how it is like driving behind someone with rear fogs on for no reason. Main use is on NS highway during heavy rains. Trust me, you can barely see the car in front.
anyway fogs be it front or rear are there to allow people to see you. its purpose is never to illuminate the road for you to see. Headlights do the job of throwing the beam forward to illuminate the road ahead. The fogs throw a wide beam to allow others to see you more clearly.
Old Oct 20, 2006 | 12:28 AM
wen pin's Avatar
Wah! not bad, can DIY! where you get ur light from and how much?
Old Oct 20, 2006 | 12:53 AM
foo77's Avatar
4th batch : Apr 03'
just want to share,i've ordered Derwankel rear rotary lamp light here's the thread: https://www.rx8club.com/series-i-exterior-appearance-body-kits-27/check-out-my-latest-creation-77979/page4/
Old Oct 20, 2006 | 12:54 AM
mkl22's Avatar
bought it from a bro here. $250.
anyway not difficult to DIY. there are instructions although its in Jap, still fairly readable by recognising the characters which are the same as chinese. Had the tools to cut the bumper also. USed a dremel. quite easy. except that i had to remove the bumper to screw in the light. was told by another forumer in the US , that no need to remove bumper, But i didn't have a short stubby screw driver to screw it in, thus had to remove bumper. Took an additional 20mins as i'm not too familiar to take it out.
DIY also has its benefits. I get good workmanship instead of leaving it to the shop which anyhow bang it in and then say sorry if they damage any part.
Also must be careful when i reverse into a lot. scraping the bumper now , might break the light. haha
Old Oct 20, 2006 | 01:51 AM
wen pin's Avatar
thks for the info. Good price anyway! Enjoy ur DIY. Should look good when done...
cheers
Old Oct 20, 2006 | 05:40 AM
BlackEight's Avatar
phor bo or som tum?
nowadays the rear light got so many options....
original mazda, monster garage led, derwankel brake light, rx8strakes led.
actually to fix the rear light no need to cut or drill or take out bumper.
i installed my own too, quite simple n fun.
Old Oct 20, 2006 | 05:45 AM
clarencel's Avatar
Which one did u get?
Old Oct 20, 2006 | 08:08 AM
BlackEight's Avatar
phor bo or som tum?
i got it from rx8 strakes
you try this link, quite fun..shows u how the light works..parking light, brake light
http://www.rx8strakes.com/index.asp?...PROD&ProdID=30
but i can't wait for the leds to blow........so i can make my own design.
kekeke itchy
akagc
Aug 11, 2015 07:07 PM
RotisserieEngine
General Automotive
11
Aug 6, 2015 06:34 PM
MatthewRJ
Aug 5, 2015 09:24 AM
SayDfuse
Aug 3, 2015 10:41 PM
Stubbs
Jul 28, 2015 09:23 PM
