Group Buy Center Approved group buys ONLY. To become an approved group buy vendor - go here:
https://www.rx8club.com/payments.php
TR-01 Rotary Engine Compression Tester - Official Group Buy
Old Sep 3, 2009 | 01:47 PM
  #201
czar's Avatar
Almost boosted
my only other concern was the connector from the plug adapter to the box(technicaly hu) it falls off to easy for me .
was about to tape it after i plug it in
Last edited by czar; Sep 3, 2009 at 01:47 PM. Reason: seriously i should learn a second language to have a excuse for sucking at english so much
Old Sep 4, 2009 | 08:41 AM
  #202
wankelbolt's Avatar
1% evil, 99% hot gas.
Originally Posted by TwistedRotors
What kind of issues did you have with tightening the sensor into the sparkplug hole? With the rubber o-ring in place it should only need to be hand tightened to get a good seal. Did it feel as thought the threads were binding up?
I had trouble when I first started using it with the shrink-wrap sleeve around the sensor slipping. I couldn't even get the sensor hand-tight, so I had to cut the sleeve off. Now it works fine and looks shiny.
Old Sep 4, 2009 | 02:31 PM
  #203
TheWulf's Avatar
My 8 looks like a Smurf
Random Q: Would this tester work on a piston engine?
Old Sep 5, 2009 | 07:45 PM
  #204
czar's Avatar
Almost boosted
retested the rear correctly this time warmed up the motorgot it tight and boom
number
115 114 117 @240 something rpms
non corrected, i didnt bother retesting the front
Old Sep 13, 2009 | 10:09 AM
  #205
Nemesis8's Avatar
Bigus Rotus
Originally Posted by r0tor
got around to checking mine...
Front: 103 102 103 at 288 rpm
Rear: 105 104 107 at 292 rpm
... looks like i'm barely below spec -sigh-
I'm lower than you, and I still get it to start every morning! LOL
Old Nov 25, 2009 | 01:09 AM
  #206
AndyRX-8's Avatar
Hi, I have already bought your tester and I want to buy two more, there is a ready?
Old Nov 26, 2009 | 10:05 PM
  #207
rx7sp's Avatar
Quebec is RX-7 & 8 land
I would be in for one unit also if still available
Old Nov 27, 2009 | 09:27 AM
  #208
mazdadude8's Avatar
I would like to know what the deal is as well looks like a nice unit.
Old Jan 22, 2010 | 12:03 AM
  #209
@!!narotordo's Avatar
FLAME ON!
I sent you a pm asking for a price quote shipped, do you still make these?
Old Jan 22, 2010 | 08:25 AM
  #210
wankelbolt's Avatar
He hasn't been on since September 3 last year. I wouldn't count on getting an answer. You might try contacting him through twistedrotors.com.
Old Jan 23, 2010 | 07:01 PM
  #211
Originally Posted by Sgt Fox
So I figured I would show you guys what I have been working on. Anyone care to check my maths?
hey Sgt, did you ever complete this?
Old Jan 26, 2010 | 08:50 PM
  #212
Sgt Fox's Avatar
Foxed.ca
I did. http://foxed.ca/foxed/index.php?page=rotarycalc
I checked it against a few of the other converters floating around. Mine seems pretty much the same as the others, aside from me taking the engine correction value into consideration.
Old Jan 27, 2010 | 05:47 PM
  #213
wankelbolt's Avatar
Nice! Thanks!
Please consider setting the code Free so those of us who don't run windows can build on the great work you've done and make it run on our machines. Might see it on a Nexus One or Nokia N900 if you do. Release it under the GNU General Public License and you'll always get credit and be able to incorporate improvements others make back into your version.
Old Jan 30, 2010 | 04:42 PM
  #214
longpath's Avatar
Is this still available, or has the group buy closed out?
Old Jan 30, 2010 | 05:13 PM
  #215
group buy is closed.
Old Feb 7, 2010 | 03:55 PM
  #216
zenrx8's Avatar
Well, this unit works well.
Just a little too well, if the stark truth isn't what you wanna see.
Installed a new blower on my '04 GT with only 15K miles on the motor.
Won't start. Tries, but won't catch and run. Truly epic flood symptoms.
After performing deflooding procedures, oh, about a zillion times (OK, only about a hundred), I hook up the tester, which worked perfectly.
Both rotors, all face values in the 50's. (That's "fifties", as in "5-OH", or "Fiddy")
Apex seals are obviously hibernating deep, deep in the rotors, and I don't think they'll be coming out in the spring. Long story, but I think the previous owner somehow managed to carbonize the motor (see: carbonite/star wars/impenetrable encasement system/jabbathehut)
But hey, at least I know what the problem is
Old Feb 7, 2010 | 04:08 PM
  #217
thewird's Avatar
Put some tranny oil through the spark plug holes to build compression and try again.
thewird
Old Feb 7, 2010 | 04:25 PM
  #218
longpath's Avatar
Has anyone been able to contact the inventor? twistedrotors.com is still up; but attempts to order through the website fail (both blue and green show as out of stock as soon as you try to order either one), and all of the emails and PMs I've tried sending also go without any response. I even tried contacting the inventor through the inventor's youtube account. I'm not expecting the group buy price; but I still want to order one because I am pretty sure my compression is fading fast; but I want to be sure.
Old Feb 7, 2010 | 04:41 PM
  #219
longpath's Avatar
Ok, plan B.... is anyone that bought one of these in the metro New York City area? I am willing to travel to you and compensate you for your time and the use of you compression tester. Please PM me.
Old Feb 8, 2010 | 07:04 AM
  #220
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
The group buy closed a while back. You might try contacting him in the 7 forum. He said he spend a lot of online time there. The tool works great........
Old Feb 8, 2010 | 07:06 AM
  #221
zenrx8's Avatar
thewird
Thanks. Been trying that, so far no luck, I keep hoping that eventually it'll soak around the springs and seal and let them release.
Old Feb 8, 2010 | 07:09 AM
  #222
zenrx8's Avatar
Keep trying; I do know this guy is busier than a Mazda Mechanic de-flooding RX8's. The unit is very nice, I feel very lucky to have gotten one.
Old Feb 8, 2010 | 07:37 AM
  #223
thewird's Avatar
Do you manually turn the engine to put a teaspoon of oil in each rotor face?
Have you considered you have a blown engine?
thewird
Old Feb 8, 2010 | 03:57 PM
  #224
zenrx8's Avatar
thewird
Wird, yeah, did that. I bought this car with 14.5 k miles last summer; put about 1000 miles on it, ran well, got normal mileage, no starting problems at all. Had a Cobb Accessport on it, uninstalled that, car ran fine, no problems. Put the blower on, suddenly it won't start. Been over the blower installation, can't find any problem. Have fuel, fuel pressure, hot battery, new plugs, new coils.
I can't understand why it won't start; the startup map for the Pettit blower is pretty much the same as the stock map. Right now the only thing I can put my finger on is the abysmally low compression readings.
Blown engine, maybe, but I just checked, it didn't have a smile on it's face or any lipstick on the exhaust...
Old Feb 8, 2010 | 04:33 PM
  #225
thewird's Avatar
By blower, do you mean the pettit supercharger? Maybe you have a vacuum leak somewhere, did you plug the map sensor back in?
thewird
