Hymee Pro Tuner Discussion
Old Oct 25, 2009 | 01:32 PM
  #176
Brettus's Avatar
Boosted Kiwi
/\ you are quite correct - my apologies . It takes some thinking to figure out what is happening
Lower the number on the Ve table and AFR will lean out . So you have to make a corresponding adjustment on the fuel table to add fuel .
Old Oct 25, 2009 | 06:46 PM
  #177
rotarenvy's Avatar
I taking a different approach. my MAF's are normally within 5% without calibration. however there are spots where I characteristically go lean. these coincide with where the valves are opening ie a change in VE. I going to try using the VE table to address these.
I don't believe that calibrating the MAF can compensate for these points properly as that would affect the rest of the MAF curve.
so which way is it?
I would have guessed .95 is a percentage and 95% of the target lambda would be applied. since lambda is smaller is richer, .95 would add 5% more fuel.
Old Nov 2, 2009 | 06:55 AM
  #178
Tsar's Avatar
Hi guys, here's a video i did rapidly this week end, acceleration is poor cause 4 wheels on the back seats and PCM not calibrated since new map the same day , but now my SP model revs to 9600 rpm :D :
http://www.youtube.com/user/Tsargate#p/u/0/blbPfYyOQh4
second gear goes to 131 km/h , here in france it's the legal speed limit on motorway
this new map will be tested on track this saturday, no CEL from the beginning and guess it will continue that way.
Old Nov 2, 2009 | 12:15 PM
  #179
Brettus's Avatar
Boosted Kiwi
hmmm - looks like the acceleration is good up to that rpm which surprises me on a 4 port ....
Old Nov 3, 2009 | 03:51 AM
  #180
Tsar's Avatar
yep, and the car was pretty heavy inside, and don't forget i have 19 wheels with 235-35-19 tires !
next saturday on track i will be running with 18 stock wheels, you will see what is the real potential on my next videos .
Old Nov 17, 2009 | 02:07 AM
  #181
Herry's Avatar
I bought it. First impression was very good. I could change many values of my car.
But my car is stopped, now. I have changed only speed limit. If you will use it, you have to back-up your ECU data.
Old Nov 17, 2009 | 02:46 AM
  #182
Brettus's Avatar
Boosted Kiwi
sounds like you erased your brain ?
I have done it and managed to resurect the ecu afterwards . Tricky but it can be done .
Old Nov 17, 2009 | 03:51 AM
  #183
SymSym's Avatar
SymSym
What Hp gains or fuel efficiency gains can be made by the Pro Tuner on NA cars. I have not tried to tune my car at all other than the factory flashes. Is it easy to improve power or fuel efficiency or will a new user be more likely to make mistakes and make a mess of the engine mapping.
Old Nov 17, 2009 | 03:55 AM
  #184
Herry's Avatar
Just to make sure. Case by case. All rx-8's ecu dosen't have same thing. Who knows what the future may hold in...
Old Nov 17, 2009 | 11:59 AM
  #185
Brettus's Avatar
Boosted Kiwi
if you don't have any automotive skills and are not willing to spend a lot of time learning - it really is not a good move .
That said , 15hp or so is about the limit of gains that can be had just by tuning .
Old Nov 17, 2009 | 12:00 PM
  #186
Brettus's Avatar
Boosted Kiwi
Old Nov 17, 2009 | 01:43 PM
  #187
Tsar's Avatar
Hi guys,
I tested my Version2 map on track and it was'nt good at all in fact , lack of power at high revs, but still no CEL like i told you.
At first we did other changes and i even tested 9800 rpm on my SP model but the engine light went quickly on at that rev so we decided not go more than 9500 for future maps.
My friend who does the changes just put me a Version3 now and it is really better, engine is very agressive and still no CEL .
I just gave the files to Kazuma to test on his, i hope he will do a feedback on this topic, so you will know if the french guys are good or not in mapping .
(here's a little fight with an FD friend when i had the V2 map last time on track, i only needed 2 and 3rd gear on this track with my 5 speed gearbox and map at 9500 rpm, but i know i should have passed 4th gear at times but i was abit lazy )) : http://www.youtube.com/watch?v=TKdu1YYaZnY )
Old Nov 17, 2009 | 01:53 PM
  #188
dmpriso's Avatar
I've got questions about the ProLogger, is this the right place to ask?
Is there some information about the data format used for export/import available? That would be great, since CSV Export does not work correctly, here is an example:
Time;Load (%);Engine Temp (°C);Long Term Trim (%);RPM (rpm);Vehicle Speed (km/h);Timing (°);MAF (g/s);TPS (%);Air/Fuel Ratio
0;23;1372549019608;16;3;1248;2157;0;24;11;3;15;686 2745098039;14;74;0;0;0
0;2;23;1372549019608;16;3;1248;2168;75;0;22;11;7;1 5;6862745098039;14;74;0;0;0
0;4;23;1372549019608;16;3;1248;2206;25;0;21;11;65; 15;6862745098039;14;74;0;0;0
As you can see, the headers don't correspond to the values, and even the format of the values changes in between.
Another question, shouldn't be there more values than just the 9 ones in the logger tool? At least in the CSV there are more ...
Old Nov 17, 2009 | 01:58 PM
  #189
Brettus's Avatar
Boosted Kiwi
/\ My dudelogger logs are graphical which I find way superior to numerical .
Old Nov 17, 2009 | 02:11 PM
  #190
dmpriso's Avatar
My intention is to parse the values with my own program for better analysation.
Old Nov 17, 2009 | 02:21 PM
  #191
dmpriso's Avatar
I noticed that digits behind a comma are not separated by a comma but by a semicolon, which makes CSV export quite unusable, alas.
Old Nov 18, 2009 | 02:56 AM
  #192
dmpriso's Avatar
My fault with the CSV export. Of course, the values are separated by ",". But with German language setting, this is also used as comma in a number. So if I change the language settings, it works correctly.
Old Dec 15, 2009 | 12:04 PM
  #193
fastlaneracing's Avatar
Rotor User
Have somebody tested pro tuner in windows 7?
Old Dec 20, 2009 | 01:32 PM
  #194
Rotor User
anybody?
Old Dec 20, 2009 | 05:36 PM
  #195
Hymee's Avatar
Race Steward
Azathoth,
The Pro Tuner software itself works, but I need to check the USB Device Drivers.
Cheers,
Hymee.
Old Dec 21, 2009 | 08:45 AM
  #196
Rotor User
Thanks Hymee, I haven't registred my hardware that I got from you some months ago.
My old computer died in a thunderstorm, but my new computer arrived today and it comes with Win7. I'll test it out.
The registration only bindes the hardware to my car and not my computer if I understand it correctly.
Old Dec 22, 2009 | 04:38 AM
  #197
Hymee's Avatar
Race Steward
Yep, when the first ECU re-flash has successfully taken place, the VIN is recorded in the hardware interface forever more. Unless you purchase extra VIN tokens, the hardware will not allow another VIN to be re-flashed. The licence does not restrict you to how many computers you run the tuning software on.
Cheers,
Hymee.
Old Dec 24, 2009 | 07:30 AM
  #198
Rotor User
Good then I can test it out in my new win7 laptop, it that dosent work I get another old win xp just for tuning.
Have a good christmas Hymee, ill send my registration soon.
Old Dec 24, 2009 | 08:42 AM
  #199
Windows 7 can run in compatibility mode by program
Old Dec 24, 2009 | 09:48 AM
  #200
Rotor User
yeah you are right, it may work out.
