DIY: No Heat? Repair the Heater Control
Rating: Thread Rating: 7 votes, 5.00 average.
Old Jan 4, 2010 | 07:06 PM
  #176
Jon316G's Avatar
Grasshopper
Originally Posted by mmGilbert
If your ac is for sure broken. Then it wouldnt hurt to go over each of the 3 solder points. All 3 of mine were bad. It just looked like a metal rod going out of the circuit board. After i put solder on each one, there was a nice pool of solder going around the circuit.
Example
I know I'm just being picky here, but even though its ideal to have the "Hershey Kiss" solder joint at the end of the lead, this isn't what you should be focused on.
You really want at least 75% vertical solder fillet in the barrel to have an acceptable connection.
The last couple temp control circuit boards I worked on had under 10% fillet.
So look at the topside of the circuit board to verify this before you reassemble everything.
Here is the page from the IPC document our factory goes by:
DIY: No Heat?  Repair the Heater Control-pth-vertical-fill.jpg
Old Jan 9, 2010 | 04:26 AM
  #177
lehal68's Avatar
72
thanks man my dad a mechanic ill get him to do it ive had this prob for a lil bit now piised me off not no more!
Old Jan 12, 2010 | 01:56 PM
  #178
88 rex turboII's Avatar
Did this method on sunday and Heater Control works like a charm now. Thank for the write up
Old Jan 18, 2010 | 12:41 PM
  #179
riceman7890's Avatar
This is awesome. Saved me 400 dollars
Just did this DIY myself. I can't believe it worked. I suck at soldering. Never soldered a circuit board in my life. I soldered the 3 connections and put everything together and went to reinstall exepecting it not to work. WRONG!!
It works perfectly! One thing I had a problem with though was getting the stereo out. It wouldn't come out so I had to to take the face off with the rest of the unit still in the dash. It was either that or rip whatever wiring harness was caught in the back. Thanks for the DIY. I am so happy to have heat again. It's f-ing COLD!!
Old Jan 20, 2010 | 03:46 PM
  #180
eduncks's Avatar
what about if my heat control and the buttons for my heat, like A/C and defrost, don't work?
Old Jan 24, 2010 | 10:52 PM
  #181
lehal68's Avatar
72
Works
it worked great did it today took about hour n half
Old Jan 27, 2010 | 09:58 PM
  #182
mrkeel5537's Avatar
Has anyone had their temp controls reversed?
Mine are totally out of wack
Sometimes Heat is on the cold side (and vice versa), whether or not the ac button is pressed can affect if the heat is on
Sometimes it works like it should
Other time only the ac works
Did the ac test where you press the on button with the scan button and the first time through it passed and then when I got to 16 it dropped to 0 and stayed there on every setting.
Haven't specificaly read any of these symptoms on here before, but I am going to attempt the soldering next weekend.
Old Jan 27, 2010 | 10:03 PM
  #183
Lunacy's Avatar
Registered Abuser
Sounds like the problem i was having at first. Then it complete crapped out.
Old Feb 5, 2010 | 06:00 PM
  #184
BigC94's Avatar
Perfect!!! Thats all there is to say. this thread is a lifesaver!
Old Feb 6, 2010 | 10:02 PM
  #185
Drakeguy22's Avatar
Drake
Man i wish i was part of this forum b4 i replaced that whole unit.....
Old Mar 14, 2010 | 06:57 PM
  #186
batangisip89's Avatar
epic stuff, works like a charm!!! i was kinda worried though because the solder points look pretty mint... but i re-soldered them anyway then now its back to working perfect!
Old Mar 14, 2010 | 09:37 PM
  #187
Jon316G's Avatar
Grasshopper
Like I posted earlier... just because the solder appears good (Hershey Kiss joint), doesn't mean the barrel fillet is sufficient.
Having the barrel filled is more important than a perfect looking joint at the bottom.
So its good that you went ahead and added solder anyway.
Old Mar 18, 2010 | 05:29 PM
  #188
bjapilot's Avatar
radio cable connectors
I attempted to remove my radio following the excellent posted pictorial instructions. Everything work fine except I could not get the cable connectors apart. I know there is a tab I have to push in while removing the connector but I could not make it work. It is hard to see what side of the connector the tabs are on. Any suggestions or is there a tool I can use?
Old Mar 18, 2010 | 05:31 PM
  #189
Jon316G's Avatar
Grasshopper
Which one of the connectors are you attempting to remove?
The large one?
Old Mar 20, 2010 | 01:19 PM
  #190
rkspaldi's Avatar
No Heat?
Man wingnut you just saved me $515.99! I owe you a 24 pack!!! Your post worked like a charm. Thanks Again!!!
Ryan S.
Old Mar 27, 2010 | 05:22 PM
  #191
jammiman's Avatar
You are the man. I just moved to AZ, and when I was in CA, I had no problem driving around with the windows down and the heat on low, but AZ is a different story. Took about 1/2 hour and made my commute SOOOO much better. Thanks, love this forum!
Old Mar 30, 2010 | 03:13 PM
  #192
balkhu's Avatar
fixed my heat/ac last weekend. seems to work perfect now.
never had a single problem with this car until 48K miles/4 years period and after that, all of a suddent, flood gates are open.....have had about 10 issues in last 12 months
Old Apr 2, 2010 | 02:54 PM
  #193
Bullitt's Avatar
In the pipe five by five.
Wingnut, you rock in epic proportions. Thank you so much!!
Old Apr 4, 2010 | 02:26 PM
  #194
tree13kadams's Avatar
just did this. the hardest part is to disconnect the damn plugs with my big monkey hands
but thanks for the help ill no lo9nger have to freeze in Michigan winters
Old Apr 4, 2010 | 11:10 PM
  #195
Bullitt's Avatar
^Ha, yeah. The hardest for me was the ash light. Actually, I never got it off.
Old Apr 21, 2010 | 03:48 PM
  #196
SebtownRx8's Avatar
75shot55fueljets=GOBABYGO
B E A U TIFUL wow just been stuck with heat for 2 years didn't mind so much and after reading this for the hundredth time decided to buy a soldergun and go to work. 1 hour total time pretty easy overall. and works like a charm. thanks again dude great thread.
Old May 6, 2010 | 05:53 PM
  #197
maybsumday's Avatar
From: Halifax.. Nova Scotia and everywhere in between...
Had the out of control heater issue and "Thanks" for all the info on this site I was able to fill the dealer in on the problem and show them how to do the test...
Under my extended warranty...Yes...Yea!
Thanks again for all the info...and go Sid the Kid...Pen's
Old May 10, 2010 | 09:51 PM
  #198
mauricewong99's Avatar
Thanks ! Fix works perfectly
Regarding the bolt on the radio..
First find the two bolts on the right side..
Then look to your top right , there's the single bolt u need to remove.
Also, if u shine a flashlight through the hole by the ignition key
it shines perfectly on that one bolt so you know which one to remove.
cheers,
Old Jun 1, 2010 | 09:05 PM
  #199
corvus13's Avatar
pallida Mors
Hey,
Worked on a friend of mine's 05 RX8 and tried this fix on two different heater control units. Inititally his was stuck at 16. Now when I try either unit in the car after resoldering both, it cycles from 13 to 16 incrementaly (ie about every four clicks it moves up to the next number) I am beginning to think there is another part of the circuit affected (by the way I solder at my day job, so I'm sure the solder joints are good). Any ideas or maybe a wiring diagram for the plugs coming out of the heater control? I took resistance reading on the pot and they start at about 20 ohms and go up incrementaly to about 300 kohms, so the pot seems to be working and then I checked the output on the other side of the solder connections and got the same readings. Any help would be appreciated.
later
corvus
Old Jun 24, 2010 | 08:26 AM
  #200
Double Down's Avatar
I had the intermittent temp locking. Only Hot or Cold discussed in this thread. I was unable to verify the problem due to having an aftermarket stereo via the Metra Kit. Don't believe the Metra Kit is the problem since it worked just fine for over a year.
Now not only do I have the temp problem, but the blower will not kick on. The other controls work such as AC, Defrost and Recirc, I have a feeling the Solder fix will no longer work for me and I'll just need to replace the whole control unit.
What do you guys think?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
