The newest 100% bolt on Greddy Hybrid turbocharger!
Old Mar 20, 2009 | 11:55 AM
  #101
Kane's Avatar
Is it wrong that I want this - just to compare to the 3071R?
Too bad I gave my Greddy away like a week before BNR started doing this....GRRRRR
Old Mar 20, 2009 | 12:25 PM
  #102
J.Cab's Avatar
1st RX8 BNR Turbo Owner..
Originally Posted by pdxhak
Someone needs to get this installed, tuned and dynoed for the greater good of the rx8 community
I am going to install this when I get..the turbo that Bryan is showing is the mine. I am supposed to receive it here real soon. I will then have a few things installed as well, then tune it with Kane's PPO2. I will post a dyno, etc. Maybe even do a pull at 14psi, with Meth of course and see what kind of numbers this thing will put out.
Old Mar 20, 2009 | 12:26 PM
  #103
J.Cab's Avatar
Kane since we will be using the same tuning software, I suppose that we should be able to compare how it performs versus the GT3071R. I am looking forward to this. It has been a while since I have driven my 8.
Old Mar 20, 2009 | 12:28 PM
  #104
J.Cab's Avatar
Originally Posted by Bryan@BNR
Here it is! Enjoy...
Bryan,
Very nice job you have done with the turbo I sent you. I didnt have a doubt in my mind that you wouldnt come through and do such great work. Let me know if you need anything from me. Like I said I will dyno this and so off your work of what this badboy can do.
Old Mar 20, 2009 | 12:33 PM
  #105
blackenedwings's Avatar
Life begins @ 30 psi
I like this.
Old Mar 20, 2009 | 01:07 PM
  #106
SiLVeRE8's Avatar
a.k.a. WhITeRE8
luckily my greddy turbo is still just sitting here uninstalled yet
Old Mar 20, 2009 | 05:16 PM
  #107
Kane's Avatar
Yeah we can - but that wouldn't be as much fun for me!!!! LOL
Old Mar 21, 2009 | 03:16 PM
  #108
gregs's Avatar
Pull My Finger
Looking at the picture if the upgrade are we still able to use the supplied greddy oil feed and drain parts and clearance shouldn't be a issue with the coolant lines?
Old Mar 21, 2009 | 03:19 PM
  #109
Kane's Avatar
Clearance is fun.... but not a huge issue.
Running the coolant lines is easy since we already have them in the car (look at your throttle body sometime).
Old Mar 22, 2009 | 11:27 PM
  #110
PhantomRX-8's Avatar
Bad Ass
Is there any price breaks if I were to buy the entire greddy kit from you and have you upgrade the brand new turbo??
Old Mar 23, 2009 | 04:40 PM
  #111
Bryan@BNR's Avatar
Turbocharger Guru
It seems like there would be enough room for the oil drain tube. If not, the water tube can be simply cut and use a rubber line to reroute. I know one water line will work. The tubes can also be moved with a screw driver and bend them whichever way you want it to point to a certain extent. The oil supply fitting I have to rethread it with a die and it bolts up to this center housing w/o any adapters or extra fittings which makes it a nice and clean install.
Old Mar 23, 2009 | 04:43 PM
  #112
Bryan@BNR's Avatar
Turbocharger Guru
I will be going to a better turbine wheel design so you have that option if you don't want to stay with the factory greddy turbine wheel. If the turbo is "new", there will be a discount issued to the customer.
  #113
RK's Avatar
RK
It's Not Easy Being Green
Jason said he is looking into that in the RX8Store vendor forum.
Old Mar 23, 2009 | 04:44 PM
  #114
Mr.&Mrs.Magic's Avatar
How much do you think install would be incase I'm too lazy? That is if yall do installs?
Old Mar 23, 2009 | 06:13 PM
  #115
J.Cab's Avatar
Ahhh man, looks like I am going to have to send it back to you for the new turbine wheel Bryan...lol
Old Mar 23, 2009 | 06:42 PM
  #116
Bryan@BNR's Avatar
Turbocharger Guru
You will be fine. Just squeeze all the juice out of this one.
Old Mar 23, 2009 | 06:44 PM
  #117
Bryan@BNR's Avatar
Turbocharger Guru
That is right. When you need this upgrade, go to Jason at the RX8 Store and he will handle the transaction.
Old Mar 25, 2009 | 10:31 AM
  #118
Bryan@BNR's Avatar
Turbocharger Guru
I posted pictures of the center housing rotating assemblies (18G vs. 60-1) in RX8 Store section. Here they are again.
Attached Thumbnails The newest 100% bolt on Greddy Hybrid turbocharger!-rx8-chra1.jpg   The newest 100% bolt on Greddy Hybrid turbocharger!-rx8chra2.jpg   The newest 100% bolt on Greddy Hybrid turbocharger!-rx8chra3.jpg   The newest 100% bolt on Greddy Hybrid turbocharger!-rx8chra4.jpg
Old Mar 25, 2009 | 10:35 AM
  #119
Hey Jason, how much would it cost for the fully upgraded turbo with the best compressor etc, water cooled and fully ported without having the original TD06 to upgrade? Just an "out the door" turbo that will work with the GReddy manifold.
I have a full GReddy kit, and a 3071R arriving by the second week of April, but if things fall through this would be my next choice. I don't have a TD06 though.
Old Mar 25, 2009 | 10:45 AM
  #120
Bryan@BNR's Avatar
Turbocharger Guru
There isn't an option if you don't have the greddy turbine housing. Sure you can find another turbine housing that will bolt up to the exhaust manifold, but all your pipes will not work. Also the clearancing will change if the turbine housing is taller. They will have to be custom made which isn't worth the hastle. Just try and find someone selling a Greddy turbo. It doesn't matter if it is trashed.
Old Mar 25, 2009 | 03:40 PM
  #121
J.Cab's Avatar
Tomorrow my BNR Greddy Upgraded Turbo arrives at my house. Then this weekend I will post up some pictures. I look forward to this Bryan, it will be kick ***!
Old Mar 25, 2009 | 03:54 PM
  #122
I meant more does Jason sell the TD06 turbo without the rest of the kit, and it would be possible for people needing just the turbo to get the TD06 + modifications. I guess it would be cheaper to just buy a crappy used TD06 off eBay or something and get it modified by you.
Old Mar 25, 2009 | 05:30 PM
  #123
arghx7's Avatar
Greddy does not sell parts of the kit separately, not unless it is to replace something that has failed. I spoke to a Greddy rep and he would not sell just the manifold for example.
Old Mar 26, 2009 | 03:40 PM
  #124
legendkurado's Avatar
can't wait to hear from you man
Old Mar 26, 2009 | 03:51 PM
  #125
pking1122's Avatar
Very interesting...
