DIY: Throttle body bypass mod
Rating: Thread Rating: 8 votes, 4.75 average.
Old Jul 9, 2006 | 08:09 AM
  #76
StealthTL's Avatar
Cool Cooling....
The point about further cooling is well taken - obviously, if you could cool it further, it would result in more "gains".
However, just filling the TB with a liquid (any liquid) is not going to help - full, empty, the body will be at the same temperature, if you think about it.
If there was a way to circulate a liquid that was cooler than ambient thru it, you would have further gain, but there isn't.
S
Old Jul 11, 2006 | 09:08 AM
  #77
toxin440's Avatar
S
sure there is -- would just require extensive modification, long story short maybe tapping the AC line and circulating the refrigerant thru the throttle body so the air would pass thru a 40 degree surface before entering the engine... but all the trouble and problems this would cause wouldnt be worth it im assuming because honestly how much gain is there to be had by passing air thru a cold chamber for the smallest fraction of a second.
Old Jul 11, 2006 | 09:33 AM
  #78
dgrx8's Avatar
FN GR8
would the TB see any corrosion w/o any coolant running through it???
would simply filling it w/ coolant would defenitely be worthless???
Old Jul 11, 2006 | 09:41 AM
  #79
toxin440's Avatar
if you had just straight water sitting in the TB, im sure it would start corroding, I capped off the top metal nipple with a little rubber cap to make sure nothing gets down in there. The other end I left open just because it's such a pain in the *** to get to. I'm not that worried about it, any moisture that MIGHT be in there would easily be evaporated off with the really hot engine bay temps.
Old Jul 11, 2006 | 09:44 AM
  #80
dgrx8's Avatar
FN GR8
thanks. i'm capped at both top & bottom... so, i guess i'm good to go...
Old Jul 12, 2006 | 12:33 AM
  #81
davefzr's Avatar
Glenn (Razz1) came over to my house the other night and helped me perform this mod as well as the oil bypass mod and the difference is noticable. Espeacilly after I performed the oil mod. I would definitely recommend performing both of these updates as I am very happy that I did this..
Thankx again for your help Glenn. These are great mods that everyone should do to their car.
Old Jul 12, 2006 | 12:34 AM
  #82
oil mod??? turbo??
Old Jul 12, 2006 | 01:09 AM
  #83
davefzr's Avatar
The breather at the oil hose exit....
Old Jul 12, 2006 | 01:11 AM
  #84
got it... i thought i missed something..
thx.
Old Jul 12, 2006 | 07:27 AM
  #85
Jaguar_MBA's Avatar
What are you folks using to cap the hole in the intake accordian tubing with?
Old Jul 12, 2006 | 11:38 AM
  #86
dgrx8's Avatar
FN GR8
hey Jag
a 3/8" rubber cap
found at any autoparts
Old Jul 12, 2006 | 11:49 AM
  #87
davefzr's Avatar
I also used some bonding silicon adhesive on all three of my caps.
Old Jul 12, 2006 | 01:12 PM
  #88
dgrx8's Avatar
FN GR8
glad to see everyone is enjoying both of these mods... i know i am!
it's really made a difference in these miami temps...
Old Jul 16, 2006 | 07:32 PM
  #89
Jaguar_MBA's Avatar
I changed the oil on my 2005 Ford Explorer 4X4 today. While I was under the hood I checked out the throttle body. The 4.0L V6 engine does not have any coolant lines attached to the throttle body.
Old Jul 17, 2006 | 10:31 AM
  #90
HCTR154's Avatar
I found a package with about 20 rubber nipple caps of various colors at O'Reilly's auto parts. Believed they were made by Moroso, so you will probably get 5-10 extra horsepower by using them!
Old Jul 17, 2006 | 12:47 PM
  #91
RX8Maine's Avatar
Has anyone tried introducing a valve switch in the feed line as was mentioned above? I would love this mod for 90 degree track days, but probably need the warming in winter here. Has it been confirmed that the bottom line is the feed?
Old Jul 17, 2006 | 05:51 PM
  #92
Jaguar_MBA's Avatar
So why do people think the RX-8 needs to have hot coolant pumped through it in cold climates when the Ford Explorer's throttle body does not have any hot coolant going throught it.
Old Jul 18, 2006 | 05:57 AM
  #93
RX8Maine's Avatar
Maybe the Ford explorer gets all of its intake air from under the hood. I don't know.
I assume Mazda went to the trouble of routing coolant to the TB for a reason and with all the flooding issues, I don't want to have idle problems and stalling when starting out on winter mornings. Once the engine is warmed up and running at 800rpm, it may have issues with condensation and poor fuel mixing when sucking in air that is -15F.
Old Jul 18, 2006 | 07:02 AM
  #94
Jaguar_MBA's Avatar
My 300ZX's throttle bodies did not have coolant lines on them (1992 model) and I lived in New Hampshire with that car for ~ 3 years....never had an issue...and that car was a complete cold air intake system.
Also it is mentioned "Starting out on cold winter mornings"..you coolant is freezing cold then after sitting all night, thus your throttle body is -15F too.
Sorry RX8Maine....I too am trying to figure out why MAzda did this....
Old Jul 18, 2006 | 10:46 AM
  #95
toxin440's Avatar
all I know is that I live in Dallas/Fort Worth, texas and right now we are hitting 106 degree temps in the daytime, it's hotter then german sheiza **** here (LoL)
I don't know if my butt could feel any improvements with the TB bypass mod but I'm happy i did it. With 106 degree temps the last thing I want is my intake air to run thru one more ring of scorching hot temps. I'm not worried about the winter time here, it gets cold but not super-freezing-*** cold.
Old Jul 18, 2006 | 01:58 PM
  #96
MazdaManiac's Avatar
^^ I'm hoping you don't actually know what "German sheise ****" is, because referring to it as "hot" is disturbing.
Old Jul 18, 2006 | 02:26 PM
  #97
toxin440's Avatar
oh but i DO know what german sheiza **** is... and it was more of a joke :-p
Old Jul 18, 2006 | 02:36 PM
  #98
Its "sheise". If you use a "Z", it becomes "sheitza", which is something else.
Still disgusting....
Old Jul 19, 2006 | 06:25 AM
  #99
RX8Maine's Avatar
That's why I specifically referred to 800 rpms. That seems to be the slowest possible speed for the renesis to run smoothly when warm. It doesn't even try to turn that slowly until it has fully warmed up.
Old Aug 6, 2006 | 11:18 AM
  #100
Ryan34's Avatar
This mod is great on F-body's, the throttle body bypass is dynoed to get 6-8 hp on camaros and firebirds.
Just to add my 2 cents
You have already rated this thread Rating: Thread Rating: 8 votes, 4.75 average.
