10 Things New RX-8 Owners should know from Day 1
Old Nov 17, 2005 | 10:44 PM
  #76
takahashi's Avatar
Good point... what they are saying is ...
You make your choice, we don't care
We all know that RX-8 is in the list of capatiblility.
The only question is what happen using ethanol blended fuel in hot summer days
Old Mar 25, 2006 | 07:02 AM
  #77
ddrx8's Avatar
Dee Dee Velocity Red
Hi there matey, I am from Brunei and I own a mazda RX 8. I just want to know how can I get the grille fo the oil cooler n the radiator? I will be going to Brisbane middle of april and wouldnt mind drop by your shop. You can email me here call sign ddrx8. Thanks
Old Mar 25, 2006 | 03:02 PM
  #78
Jambos's Avatar
Hi
You should PM Hymee as he is the one who sells the grilles.
I will be at the airport in Brunei for 2 hrs on my way to London on the 30th April.
If you don't make it to Brisbane maybe I could drop it off on my way through?
Laurence
Old Mar 25, 2006 | 08:35 PM
  #79
Revolver's Avatar
Shootin' from the hip
Taka,
Quite a few of us have now had to replace engine mounts (mine are getting done tomorrow). I wonder if we should post something here so people buying second hand know to check for that potential problem.
Old Mar 26, 2006 | 03:05 AM
  #80
Hymee's Avatar
Race Steward
I am getting one of my engine mounts replace under warranty soon as well.
Cheers,
Hymee.
Old Mar 26, 2006 | 04:32 AM
  #81
takahashi's Avatar
Any symptom that I could add?
Old Mar 26, 2006 | 04:30 PM
  #82
Revolver's Avatar
I'm not sure if symptoms differ but for me at least there is increased noise and vibration in the drivetrain at idle that disappears when the accelerator is pressed. Tell tale sign is increased shake of the gear lever at idle.
Old Mar 26, 2006 | 06:08 PM
  #83
takahashi's Avatar
Me too last time they did not see anything but I went to Berwick Mazda (sigh)...
I will book again this thursday to be looked at.
Old Mar 26, 2006 | 07:59 PM
  #84
Student Driver
Cheers,
Hymee.
Got mine replaced about 2 weeks ago and the vibration has improved 70%.
Still about the same (as prior to replacement) when it's cold.
Old Mar 27, 2006 | 02:27 AM
  #85
gibbon's Avatar
Is this engine mount problem appearing at around the same ballpark km's for you guys?
That'd be useful info to know.
Cheers,
Mat.
Old Mar 27, 2006 | 03:41 AM
  #86
Gomez's Avatar
Shifty Bastard.
You wont have to worry, gibbon. You have the latest spec mounts on your car.
Old Mar 27, 2006 | 04:05 AM
  #87
takahashi's Avatar
Mr. Sam in City Mazda just look at mine.
He said mine is perfect.
The rattle is from the gauges or all that "geeskmo" I installed on the dash
Old Mar 27, 2006 | 05:03 AM
  #88
gibbon's Avatar
I figured it wouldn't have affected me for a long time anyway, but I didn't know mine had updated mounts. Nice, thanks.
Incidentally, I've been more or less following Taka's running-in method from earlier in this thread (slowly building up the revs), and the car has 1,300km on it and a fresh gut full of Mazda Rotary Oil in it now, so I'll start to strectch its legs a little over the next few days. I have another 300km drive ahead of me tomorrow
I'm discovering the addictive nature of the RX-8. I was supposed to spend last weekend packing and cleaning my apartment (I'm moving), but I kept on finding reasons to go for a drive and ended up getting bugger all done I even went for a drive down to the Gold Coast to go to KMart
Old Mar 27, 2006 | 04:38 PM
  #89
Revolver's Avatar
Well I picked up my car after work yesterday after having the engine mounts replaced.
Seems to have cured all of the vibration at idle. Can't comment on the 70% assessment posted above yet - too short a run home to really notice any residual problem. Will see what it's like next time I take it for a longer run.
Old Mar 27, 2006 | 04:40 PM
  #90
Revolver's Avatar
Cheers,
Mat.
'Mez seems to have answered your question but for what it's worth mine kicked in a tad over the 22K mark.
Old Sep 29, 2006 | 10:53 PM
  #91
Cromax's Avatar
Buzz Buzz Buzz
I think I lost an engine mount last week. It's idling rough and the gear stick is moving excessively compared to how it was before. Also it tends to rock a bit under very slight acceleration in heavy traffic.
I'll get it checked out on my 60k service. Haven't had this problem before btw.
Does anyone know of any solid replacements for the engine mounts though?
Old Sep 29, 2006 | 11:26 PM
  #92
Richard Paul's Avatar
You have bigger problems then that. A broken mount doesn't make it idle rough. You best look elsewhere. How's the performance? If the performance is off have someone check the engine.
Old Sep 30, 2006 | 05:29 AM
  #93
azzaboynt's Avatar
maybe you need a coat of paint on your calipiers.
or as richard says, get it checked out with your service centre. anything that "suddenly" happens has got to be bad news.
Old Sep 30, 2006 | 03:57 PM
  #94
Cromax's Avatar
Buzz Buzz Buzz
Performance is fine ... it's just engine mounts. Just checked it yesterday afternoon at a mate's place. If anything else is wrong I'll be quite amused.
Old Oct 2, 2006 | 08:34 AM
  #96
Cromax's Avatar
Buzz Buzz Buzz
Has everyone experienced problems with engine mounts? Is this an inherent problem with our cars?
Old Oct 2, 2006 | 08:49 AM
  #97
takahashi's Avatar
Some dealer loves to do warranty job. And they are surely justify it.
In consumer point of view - engine mount is a wear and tear item - of course it is good to have a new one. :peace:
Old Oct 2, 2006 | 09:52 PM
  #99
Revolver's Avatar
Although I'm sure Taka is right about some instances of 'warranty' work, there are a number of us who experienced vibration symptoms of one kind or another that disappeared after upgrading the mounts. I believe that after a certain build date all new cars were fitted with the upgraded mounts, so it shouldn't be an ongoing problem.
A search might yield more info...
