DIY: Custom Sub Box Install- pics and plans
Rating: Thread Rating: 4 votes, 5.00 average.
Old Apr 12, 2004 | 05:29 PM
  #51
G8rboy's Avatar
Mmmmm... Rotary Donut
Originally posted by mateo
OK, great. I'll be running my Amp powerup wire to there as well. I think others have discussed it in other a couple other messages but does your amp turn off properly when you attach to the cig lighter? Others have reported "popping" sounds due to the initial power surge when you turn things on and off..(?)
Yes- the amp powers up when I move the key to 'Accessory' or start the car, and it turns off when I turn off the car. Mine does not pop at all, but I think that might have more to do with the Amp than anything else. So far my Alpine setup has been perfect...
Old May 2, 2004 | 09:17 PM
  #52
RX8FanMan's Avatar
JRizzle
doesnt a system mess with the 50/50 weight distribution?
Old Sep 7, 2004 | 11:09 AM
  #53
G8rboy's Avatar
Update and long term results...
Just wanted to update this thread with my latest mod- I added the PIE Mazda-> Alpine adapter box combined with the Alpine-> RCA adapter cable for a seamless line-in for my RCA 40gb Lyra mp3 player, and my system sounds fantastic. Details on that mod can be found here:
https://www.rx8club.com/series-i-interior-audio-electronics-24/pnp-aux-solution-pie-alpine-adapter-31969/
Also, I'm still running without a line-level or line output converter and have had no problems whatsoever.
Old Sep 9, 2004 | 07:25 PM
  #54
irfan's Avatar
ElusiveSasquatch
Id like to see your plans in GIF format. I have a pair or Kappa Perfect 10.1s and Id like to make them fit. the 65degree slope is great to know. How many cf is each section of the box? mine need .60 each. i have a 600W JBL powering them, did you need a cap?
Old Sep 9, 2004 | 08:46 PM
  #55
G8rboy's Avatar
See the second page of this thread for the plans... I posted them there somewhere. I think I designed my box was about 1.3cu ft total, minus the partition would give you a hair over .6 cu feet each, so this should work great for you. You can also stretch the box out left to right for a little more volume if you think you need it. I did not use a cap, but I'm not pushing them nearly as hard as they could be (or you might be with 600W).
Old Sep 9, 2004 | 11:50 PM
  #56
irfan's Avatar
ElusiveSasquatch
i must have missed that, thanks.
as for remote on: many amps have auto on from high level inputs... if you use speaker level inputs instead of RCAs , your amp should turn on only when it recieves an audio signal, this eliminates the need for remote leads.
Does anyone know how much watts go to the 6x9s? I dont want to mess up the inputs with too much power.
Old Sep 10, 2004 | 12:08 AM
  #57
G8rboy's Avatar
My old Bazooka was like that, but my Alpine required a 12V signal to turn it on.
As for the power to the 6x9's, probably depends if you have Bose or not. I think you'll find the signal cleaner if you tap into it before the amp instead of speaker level.
Old Sep 21, 2005 | 09:46 AM
  #58
BomberNYC's Avatar
posting to make pictures appear
Old Nov 11, 2005 | 12:49 AM
  #59
marvin_rock's Avatar
L8 BLOOMER
Still no word on whether you would make one of these for sale. Honestly I'm completely audio retarded and didn't understand 1/2 the things you guys were talking about here, but I do want to learn and am trying to piece things together. I just know I want a sweet system, and you have the best looking one I've seen so far. Thanks
Old Nov 11, 2005 | 12:55 AM
  #60
L8 BLOOMER
Holy crap this was one hell of a dead post. Sorry about that.
Old Nov 16, 2005 | 09:55 PM
  #61
B-Ron's Avatar
Hey i got a question that probably was answere somewhere else but im lazy....Ive been wanting to install my 10" Type R's but i stoped by a local shop and they said that with the bose system you would have to replace the wireing and **** to hook up the amp! Two places have told me that now...is this bullshit or what? If it is true then is there a not horrible explensive way of getting around it?
Old Nov 16, 2005 | 11:00 PM
  #62
G8rboy's Avatar
Nah- that's BS... tap into the pre-amp wires I showed in the pics on page 3 coming from the head unit, and run those into the amp's line-level input. I've been running this setup for almost 2 years now with no problems... no line level converters or other wiring... nice and cheap
Old Nov 25, 2005 | 04:17 PM
  #63
gnathen's Avatar
Rca connections?
[QUOTE=G8rboy]Nah- that's BS... tap into the pre-amp wires I showed in the pics on page 3 coming from the head unit, and run those into the amp's line-level input. I've been running this setup for almost 2 years now with no problems... no line level converters or other wiring... nice and cheap [/QUOTE
i want to use this setup but the amp i want doesnt have speaker lvl connections only rca imputs. How do i wire it with rca connections?
Old Dec 20, 2005 | 11:51 PM
  #64
BomberNYC's Avatar
Your going to need a line level converter so that you can take the signal comming from the head unit and turn them into RCA outputs.
Old Dec 21, 2005 | 12:16 AM
  #65
G8rboy's Avatar
Yes, that's the way you should do it, but I didn't... I just made an RCA-to-line-level cable by cutting a standard RCA cable pair in half and stripping the wires, and used those stripped ends to tap into the pre-amp speaker signals coming from the head unit, and plugged the RCA's on the other end into my amp. It's been working for my Alpine for almost two years now...
Old May 6, 2006 | 08:24 PM
  #66
supra0083's Avatar
Preamp input into Line-level vs Speaker-level
I just installed an amp and a sub today. Initially, I was taking the preamp (Bose) input into my subwoofer amp (which is a Profile HA700M) high-level input. The result was very weak bass. It does add some overall but not what I was looking for. Then I redo it by hooking it up into the line-level input, the difference is the world. I would just like to share this experience with you, so that you don't freak out when you got weak bass coming out. Thanks everyone for contributing to this thread, it was very useful and assuring.
Old Dec 7, 2006 | 11:35 AM
  #67
firebirdude's Avatar
User and Abuser
So I'm a little confused now after all this..... all I have been reading on here says that you must use a summing LOC such as the Audiocontrol LC6i or such....now you're saying I can use any ol LOC or even directly into the amp (if supported)? What would be the advantages to using the LC6i? Just more adjustability? Not worth $100-$200 and pain of installing IMO.
EDIT: Also found a similar box on Ebay. Looks a little better even. No offense, but it's fitted to the RX8 perfectly.
Old Dec 16, 2006 | 05:42 PM
  #68
tournapart's Avatar
Your Mom is ******
that ebay box is sick....
i still give alot of props to this guy because he designed it himself and posted the design on here....we all appreciate it
Not sure when ill beable to afford to do this, but....this knowlege helps me alot, as i was unsure myself how to go about it, but i have a base stereo, how different is it and what am i going to have to do different?
thanks
zach
Old Feb 26, 2007 | 07:38 PM
  #69
tournapart's Avatar
Your Mom is ******
I have a base stereo, how should i go about getting RCA output, ive already found a remote signal turn on that runs from a speaker signal, but do they make line converters from regular speaker wire signal to RCA output?
any help is greatly appreciated
Old Feb 26, 2007 | 11:16 PM
  #70
paulmasoner's Avatar
Asshole for hire
for what its worth.. i just recently got the box off ebay from ZEnclousres... cant say enough about how nice it is!!
Old Apr 28, 2007 | 06:08 PM
  #71
tournapart's Avatar
Your Mom is ******
yesh i got the box too, its awesome! cant beat the price either, 150 shipped
Old May 18, 2007 | 10:31 AM
  #72
User and Abuser
Question for you all. Getting a remote turn on for your aftermarket amps. I realize you can tap off any acc power plug, but those with the Bose system should have some other easier options correct? Measuring with my DMM at the Bose harness, I noted that the yellow/white and pink/black wires are hot only when the key is in the acc mode. Makes no difference if the headunit is on or not. Anybody know what exactly these two wires are for?
Old May 25, 2007 | 06:56 PM
  #73
RotaryBred's Avatar
i'm suprised this thread is still going after over 3 years LoL..
Try going on ebay and search for "RX-8 Sub" and check out this box i found...
it's a lil too small to add ports (if you don't know, most ported box volumes should be almost twice the volume of sealed boxes) and i wanted to build a box with a rear center-firing slot port with a custom port mounted on that rear center access panel going straight from the interior to the rear of the box. I'm working on designing and then building a deeper box with a custom fitted baffel that will add about .75 cubic feet to the volume..
Most likely i will just buy a box and modify it with the added port and baffel.
unfortunately i will have to add that on after i put the "main" box in the trunk so removing it is gonna be a pain in the *** if i ever have to, let alone installing it in the first place.
With it i will be installing a pair of MA Audio HK120xc subs and powering them with a MA HK1998 1200 watt amp...
but first things first... buy the wood and a spiral saw. I'll post pics next month or whenever construction starts.
For those of you who want a sealed box, that ebay listing is worth checking out
Old May 25, 2007 | 07:07 PM
  #74
User and Abuser
Originally Posted by RotaryBred
it's a lil too small to add ports (if you don't know, most ported box volumes should be almost twice the volume of sealed boxes) and i wanted to build a box with a rear center-firing slot port with a custom port mounted on that rear center access panel going straight into the box. I'm working on building a deeper box with a custom fitted baffel that will add about .75 cubic feet to the volume..
Most likely i will just buy a box and modify it with the port and baffel.
Already way ahead of you. Got one with a single 12" hole justified to the driver's side. Cut a 4 1/2" circular hole and added some 4" PVC piping. Tuned to 32Hz and sounds awesome. Not only is it louder than it's sealed counterpart, I get much better low frequency extension. The subwoofer I choose plus the semi-low tuning freq makes for a pretty evenly flat roll-off at all frequencies. No annoying overly-powerful thumps at certain parts of certain songs.
Old May 27, 2007 | 07:41 AM
  #75
RotaryBred's Avatar
If i was planning on using a single sub i would do the same thing.. but i would still port that box into the cabin of the car, i think it would make a hell of a difference, those leather seats must dampen the sound like crazy as well. How much difference does removing the center cover make?
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
