Fuel Injector Info
Old Feb 28, 2009 | 11:36 PM
  #51
paulmasoner's Avatar
Asshole for hire
Originally Posted by Rote8
Anyone got a picture of the injector wiring?
The diagram with the rear secondary and front P2 the same color wire has got me pissed off.
I have also been told the secondaries come from the wiring harness by themselves.
I guess I am just old school and can't see the difference between black with blue wire and black with blue wire......
A picture really is worth a thousands words here.
The ECU wiring does not match a 2007, I was going to cleverly use my LAN pinger to prove which wire goes where......
At least I did take a picture of the primaries.....
Of course I didn't touch those.....
if you look at this pic close, notice that the Front P1 and Rear P1 are wired side by side. As well secondaries and P2's.. if you trace the black/blue wire back to the connector, you should be able to determine which is which
Old Mar 1, 2009 | 07:31 AM
  #52
Rote8's Avatar
I like that idea.
Old Mar 1, 2009 | 11:40 AM
  #53
Rote8's Avatar
Injector wire tips for 2007
Number one tip, take digital pictures and mark the leads before removal.
I hope this is correct, please feel free to correct any errors....
Fuel Rail 1 (two injectors)
Both leads for this fuel rail come off of the main harness together.
Front rotor injector wire color is light-green and red. (Front Primary 1)
Front injector Wire lead has White colored tape
Rear rotor injector wire color is light-green and black. (Rear Primary 1)
Rear injector Wire lead has Tan colored tape.
Fuel Rail 2 (four injectors)
The two center (the middle) injector wires come off the harness together and split.
Front side of the middle split has Yellow colored tape.
Rear side of the middle split has Green colored tape.
The two end (front and rear) injector wires come off the harness separately and have no colored tape.
The front injector wire is Green and Red. (Front Secondary)
The front rotor middle injector wire is Black and Blue. (Front Primary 2)
The rear rotor middle injector wire is White and Green. (Rear Primary 2)
The rear injector wire is Black and Blue. (Rear Secondary)
Old Mar 1, 2009 | 11:58 AM
  #54
MazdaManiac's Avatar
OK.
I'm having difficulty in understanding what you are trying to clarify.
You just spelled out, in somewhat lengthy prose, exactly what is shown in the diagram I posted at the beginning of the thread.
Just follow the diagram. Its all shown for you there in intimate detail.
Old Mar 1, 2009 | 12:21 PM
  #55
Rote8's Avatar
Originally Posted by MazdaManiac
OK.
I added the tape colors....
I also wanted to add way the wiring pairs split from the harness.
Seriously, what really confused me was that a 4 port also has secondaries, but the 6 port calls those positions P-2, so in some places, the manual seems to call the 6 port P-2 spot "Secondaries".
(Which would make my 4 injector rail colors wrong if the secondaries were supposed to be in the middle)
I am very glad to know the color order is correct, and thank you for posting the original.
Old Mar 21, 2009 | 12:55 PM
  #56
PRX8's Avatar
Sorry if this is a noob question, what is a safe cc # for N/A RX8 to upgrade primary & secondary injectors using the stock ECU.
Old Mar 21, 2009 | 01:38 PM
  #57
Absolutely no reason to do this.......
There is more than enough fuel for any NA application with the stock injectors
Old Mar 21, 2009 | 01:49 PM
  #58
PRX8's Avatar
Thanks for the clarification, reason I asked is when I changed my plugs and spark plug wires this Pepboy Seller said I can upgrade my injectors for better performance for $25 and keep my OEM ECU, I knew at first he didn't knew what he's talking about cause he tried to sell me Synthetic oil and that's a NO BUY.. jeje
Old Mar 21, 2009 | 01:52 PM
  #59
Wow...those are cheap injectors
The ECU could likely handle +/- about 15% and still give you enough trim left to work
Old Mar 21, 2009 | 03:37 PM
  #60
Philip_SA's Avatar
Rotary lover
Hi
On the injector issue
i am porting a bit etc on my 8 with rebuild,
you guys say injectors is big enough,
but my question is if anyone knows if there is a maximum (not thinking of 100% duty cycle) but a maximum in the program on ecu to say no more fuel, like a limit or will it still first look at the sensors to first
I am just worried i start to run lean if it so happens the ecu has a upper limit
anyone know?
thanks
Old Mar 21, 2009 | 05:21 PM
  #61
ASH8's Avatar
Super Moderator
Jeff.... AKA MazdaManiac could help here...
Old Mar 21, 2009 | 06:20 PM
  #62
Considering the stock tune is 10-15% rich at higher flow rates anyway ( CAT cooling) ...the porting if it improves flow at higher rates will likely be no problem (even without a tune)
Old Mar 31, 2009 | 10:34 AM
  #63
illjordanz's Avatar
okkkk
Old Apr 24, 2009 | 06:36 PM
  #64
PhantomRX-8's Avatar
Bad Ass
Is there a chart anywhere for what size injectors to upgrade to while running a turbo?? I am going be getting my turbo upgraded by BNR and they said it should be able to handle 360whp. I only wanna run about 325-330whp. Is there a chart or anything that explains which injectors I should change out and to what size? Im still learning the fuel system on this car. Thanks!! By the way, this thread is the product of a search!
Old Apr 24, 2009 | 09:54 PM
  #65
Race Roots's Avatar
Former Sponsor
I have 650cc High Impedance injectors I was about to release...
Two options Plug and Play and ones that you solder...
Shoot me a PM I will have these ready for everyone to buy Monday
Old Apr 25, 2009 | 10:04 PM
  #66
Race Roots's Avatar
Former Sponsor
Another drive-by advertisement that fails to answer the question............
My apologies for not elaborating more, Monday I will provide a breakdown for you.
Old Apr 26, 2009 | 09:46 AM
  #67
You 2 are funny You both should be in the "special" Olympics for sniping
Old Apr 26, 2009 | 09:52 AM
  #68
I won't even try bowling...it would just be further conformation for me .......
Old May 25, 2009 | 01:11 AM
  #69
monzue's Avatar
Persistance
Hey MazdaManiac!
Since this is a thread with injector information, could you also post what size fuel injectors that Mazsport used to sell with their Fuel injector kit upgrade? The reason I am asking is because I currently run the Interceptor-X and I want to switch to the Cobb Access port with a tune done by you. I know that I need to know my injector sizes in order to get a base map, so I need this information or a way to find out this information.
on my invoice, the part number was Injector-Kit-RX8 and they were selling them for around $560.
Old Jul 12, 2009 | 07:23 PM
  #70
olddragger's Avatar
has anyone just removed the pintle caps to increase flow?
olddragger
Old Jul 12, 2009 | 07:26 PM
  #71
05rex8's Avatar
sold the 8... :(
olddragger
http://kgparts.com/index.php?page=rx8modinject
I have these which is basically what you are asking
Old Jul 12, 2009 | 08:04 PM
  #72
olddragger's Avatar
what was the flow rate off the ones you did ?
olddragger
Old Jul 12, 2009 | 10:30 PM
  #73
05rex8's Avatar
sold the 8... :(
here is the flow sheet they provided
File Type: pdf
Old Jul 14, 2009 | 05:17 PM
  #74
olddragger's Avatar
whoa!
OD
Old Jul 14, 2009 | 05:38 PM
  #75
carbonRX8's Avatar
U-Stink-But-I-♥-U
Originally Posted by monzue
Hey MazdaManiac!
Uh, I am not jeef, but I have the injectors that Scott sold. He sold 650cc/min Sieman Dekas (High impedance) and 780cc/min Densos (IIRC) that were low impedance. While it has not yet been proved by a failure and I ran the 780s for several weeks, you should not run low impedance injectors on the stock pcm as it likely does not have drivers to run low impedance injectors (the int-x does.) Again, while I dont know of any failures, running low impedance injectors on Honduhs has fried boards in the past.
If you followed Scott's suggestion on where to put the injectors, you may want to consider switching the larger injectors to bank two. (As you will be pulling the 780s.) You can get 650s from Fluid Motorsports. Make sure they are machined correctly. (The ones you got from scott had machined collars. )
